Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
reverse light??
Old Oct 5, 2004 | 06:13 PM
Assassin's Avatar
Default reverse light??
did anybody else have there reverse lights not working after a little joy ride?, I think the electronic sensor on the transmission has come loose or is defective...... the lights work w/ the alarm but in reverse they dont come on... the fuse is good, I think when I barked 2nd the other night something may have come loose..... any other experiences like this?
Old Oct 5, 2004 | 06:39 PM
H-5-L's Avatar
Wass-up bro..
Do your day time running lights work,the orange front corners?If not,some owners take out the fuse to disable the daytime running lights,this also disables the reverse lights.But the reverse lights will still flash with the alarm.If i remember right,it's fuse # 2.Should be labeled on the under side of the fuse cover.If it's not that,it's probably the switch that contacts the shifter,may need an adjustment.Good luck man.
Old Oct 6, 2004 | 01:06 AM
Assassin's Avatar
nope running lights are still working....... btw, how wuz the show?
