Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
LS1 edit disable Active Handling?
Old Oct 10, 2004 | 12:18 AM
David Gordon's Avatar
Default LS1 edit disable Active Handling?
Can LS! edit disable the active handling, has anybody tried this?
Old Oct 10, 2004 | 05:34 AM
2MuchRiceMakesMeSick's Avatar
Isnt there a switch on the console to turn it off?
Old Oct 10, 2004 | 10:32 AM
No that switch ajust the shock furmnise or something like that.
I have been having this problem for over a year. When I drag race the car on sticky tires it cuts down on power when the tires hook and the service active handling light comes on. The car goes into limp mode for about 3 seconds then slowly recovers. It sucks for drag racing as the car will always bog bad if it hooks up at all.
Old Oct 10, 2004 | 02:16 PM
JD_AMG's Avatar
Im pretty sure to you hold down your t/c button for five seconds to disable active handling.
Old Oct 10, 2004 | 04:23 PM
I know that as well but it still will not undo the problem I have.
Old Oct 10, 2004 | 05:26 PM
66ImpalaLT1's Avatar
no ls1edit cant fix that. find the codes that are being set when service active handling comes on and then look in the service manual.
