Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
suspension dudes in the know,little help please.
Old Nov 4, 2004 | 03:33 PM
more carbon's Avatar
Default suspension dudes in the know,little help please.
lookin for z51 springs for a 97 vette,is another name for these f45???? thks for any help.
Old Nov 4, 2004 | 05:09 PM
phoned LG and f45 is standard suspension,z51 is same spring but mag particle shock fluid.a better spring would be the z06.
Old Nov 4, 2004 | 07:20 PM
Snow Dog's Avatar
good info to know
Old Nov 5, 2004 | 10:45 AM
99C5JA's Avatar
Hmm. Z51 has the option code FE3. F45 is the pre-magnetic adjustable suspension code. It does not use the Z51 springs, it uses base springs afaik. FE1 is the base suspension. FE4 is the Z06 suspension. I am not sure what the new magnetic shock code is. It may have taken over the F45 code. The FE3 and FE4 suspensions share the same front spring. Rear springs are different. Some say sources say the Z51 spring is stiffer, others say the Z06.
Old Nov 6, 2004 | 12:08 AM
i thank ya for that,that guy at LG did not know springs.i was told the z51 springs are a good upgrade.if ya can't find them go all out for z06 springs.i will try used vette guys for these springs as new ones are 1100 each. thks for the info.
