Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Corvette Garage Backbone Plate
Old Nov 11, 2004 | 11:28 PM
C5 Forever's Avatar
Default Corvette Garage Backbone Plate
Is anyone running this yet? If so, how do you like it. I imagine it should stiffen up the car a bit.
Old Nov 19, 2004 | 06:54 AM
vettenuts's Avatar
I am running a Backbone from VnM and the change is very noticable.
Old Nov 19, 2004 | 05:18 PM
C5 Forever's Avatar
Who's VnM? I've never heard of them.
Old Nov 21, 2004 | 10:45 AM
REDGAR's Avatar
more info on the backbone plate please?
Old Nov 22, 2004 | 04:11 AM
vettenuts's Avatar
VnM is VettesnMore, Mark Dawson. Plate is 1/8" stainless steel with a ceramic coating.
Old Nov 22, 2004 | 08:54 AM
FreighTrain T/A's Avatar
what does it do if you dont mind a rookie question??.
Old Nov 22, 2004 | 11:03 AM
REDGAR's Avatar
Crypt, I found this that may help http://forums.corvetteforum.com/showthread.php?t=933247
Old Nov 22, 2004 | 11:20 AM
Looks almost useless. I dont know what its ment to do but it looks more like a heat sheild for our center counsols than anything else.
Old Nov 22, 2004 | 02:37 PM
REDGAR's Avatar
Looks like it's first purpose is to stiffen the chassis and the second is as a heat barrier.
Old Nov 22, 2004 | 07:41 PM
Snow Dog's Avatar
interesting. i would think its along the lines of subframe connectors for fbodies. its a proven part, but it doesnt make the biggest impact like stiffer shocks or sway bars.
with over forty bolts holding it, it was and is intended to be a brace. however in that link the guy says it marries the suspension to the body. the tunnel cover is on the body only. doesnt touch the suspension at all. just stiffens the body even more.
Old Nov 23, 2004 | 04:11 AM
vettenuts's Avatar
Originally Posted by REDGAR
Yep, thats the one I installed. It actually is very noticable when you install it. The car feels much tighter. Note that the C6 has a stiffer plate than the C5 so GM must have been aware of the advantage.
Old Nov 23, 2004 | 06:59 AM
Okay. Now here is another question. Are there any issues with ground clearance on a car that has been lowered using stock bolts and with long tube headers??? Does this piece fit with out having to bend the long tubes at all??
Old Nov 23, 2004 | 02:52 PM
vettenuts's Avatar
Yes, it is tucked way up in the tunnel above the pipes.
Old Nov 23, 2004 | 06:55 PM
Snow Dog's Avatar
you wont have any ground clearence problems on a lowered vette with long tube headers. the problem you will have is getting a jack under the side. youll need to drive up onto small peices wood or ramps.
Old Nov 24, 2004 | 06:48 AM
having that issue now. I was only wondering about the plate if it bending the long tubes needed to be done to make this fit correctly.
Old Nov 24, 2004 | 10:41 AM
vettenuts's Avatar
Not sure I understand your question, but for further background there are actually several plates out there. Some are stainless and some are aluminum, with the aluminum being thicker. If you have marginal clearance between the O2's and the tunnel plate now, then the thinner stainless plate is probably your best candidate. One other note if you have LG's already installed, I have read from some that installing the plate with those headers (and the Dynatech's too) is very difficult and the headers may have to come off first.
Old Nov 24, 2004 | 11:05 AM
What my concern was is how thick the plate is to sit above the headers. From my understanding all aftermarket headers sit well tucked under our cars. Now you add lets say 1/8 or 1/4 inch making the headers to have to clear that as well. I don’t have headers now but if I were to buy the plate and headers I don’t want the headers or collectors to rub against the plate an dthen have to bend the headers or compromise something else. That’s why I was asking if the headers needed to be bent. I should have clarified. I apologize.
You say they make different plates in different metals. Now if you’re doing this mod what metal and thickness has been proven to work most effectively.
Old Nov 24, 2004 | 01:32 PM
vettenuts's Avatar
Well, this is actually a big argument. The stainless should be stiffer due to the different material modulus and according to my calcs you would need triple the thickness of aluminum to equal the stainless. Being thinner, and coated as a bonus, I went this way just in case my O2 sensors got too close. On the system I chose (QTP's), you can rotate the pipes that have the rear O2 sensors so it was very easy to ensure this was not an issue. Also, on the QTP's, the front sensors are forward of the plate and not an issue. On the Dynatechs they are angled and directly under the plate. Several have indicated that the stock plate had to be dimpled with a hammer to fit the front sensors in. I didn't like that option at all. Not sure on other header systems, but very few have complained about the plate getting in the way.
