Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Why are Corvette headers so overpriced???
Old Dec 23, 2004 | 01:08 PM
Termin8r27's Avatar
Originally Posted by 2002C5COUPE
I have a Dynatech Supermaxx system that Ill make you a good deal on. Ill sell it for 60% of what i paid for it new!!
If you're offering it to me...thank you very much!
I'm actually looking for a plain ole set of headers and building a custom X-pipe system. I can't believe TPIS and the like charge so much for the same type of longtube found on most cars like the F-body. I was just venting/complaining/sharing on how bad it is that these vendors can take advantage of the vette consumer...
It does make sense though that most of the vette owners (if they mod at all) probably buy a complete system and expect it to have a premium price tag. (funny too cuz there's always a better, more expensive car out there...)
Old Dec 23, 2004 | 07:42 PM
ToplessTexan's Avatar
Originally Posted by Insomniak
also have a question.. which X-pipe works best and has best clearence.. i'm thinkin of doing dual cutouts.. i noticed most vette owners don't do cutouts guess i'm a lil ghetto i'd like the sound w/ the g5x3 extra lopey sound and probably gain a lil bit of top end
Watch out on cutout placement. Too much heat on the rear spring can cause premature failure.
Old Dec 25, 2004 | 10:58 PM
Kap_99C5's Avatar
One thing to consider about the "corvette tax" is that production numbers for Vettes is far less then then for the F-Bods.... That means that the cost of R&D is spread across less units. Not trying to justify the 1800 my LG's with cats cost.. But it is part of the fact of life. Part of why the longer the C5 has been out, prices have dropped some for aftermarket parts over what they were a few years ago.
Old Dec 28, 2004 | 07:20 AM
ROJO99's Avatar
Good deal for someone... Too bad I have a 99.
Old Dec 28, 2004 | 01:32 PM
vettenuts's Avatar
Originally Posted by Snow Dog
the QTPs if im not mistaken are a SS version of the TPiS peices. they use the same cat and xpipe from random tech that the TPiS headers do, course that may be the only thing similar about them.
a pair of random tech cats behind any longtube header is a good combo. good power results, not too noisy, and should pass a sniffer test still
No they are not the same or even remotely similar to the TPIS which are a mid-length 4-1 design. The QTP's are one of three Tri-Y header designs for the C5. Bellanger, Bassani and QTP are all Tri-Y, which are more complicated to fabricate but typically yield better low end torque without sacrificing upper end peak HP. Of these three, only the QTP's are stainless steel. Check out the article below for more information on this design:
Header Article
Old Dec 28, 2004 | 06:51 PM
TPiS's Avatar
Tenured Member
Let me try to explain the difference in cost. first is volume, we sell a lot less c5 than
f-car. second the more bends and the more welds on a header drive up the cost. Our C5 header also features our power h-pipe which lets each cylinder see both cats. Our 3 inch collector that merges down to 2 3/4 inch and then back to 3 inch ensures tremendous velocity. A standard 3 inch collector is about $10.00 each. Our C5 is about $35.00 each plus the cost of making the h-pipe..
As for performance all of our headers have been tested by many of the leading tuners and we are always plus or minus of everybodys other header. We normally have a higher average power number.
We do not copy other manufactuers. in fact we were the first on the market with a C5 header.And have been copied by several others poorly. also firstwith C6 and the CTS_V header.
We always stand behind our products. We currently do all of our ceramic coating in house after some issues with JETHOT.
Myron Cottrell,pres.
TPIS
Old Dec 29, 2004 | 08:21 AM
ROJO99's Avatar
TPiS, Two questions. Does your system attach easily to the factory mid section? Are you running any year end specials on the Headers for a 99 Y-body, coated? I am in the market.
One more, can/should the factory mid section be used effectively?
Old Dec 29, 2004 | 09:25 AM
TPiS's Avatar
Tenured Member
We do from time to time have what we call scratch and dent. currently we have four sets. These are cosmetic and will not effect performance.
I will discount these $75.00
Our system requires cutting and welding, It takes us about 45 min for the procedure.
The factory mid system is ok for 383 and 350 cid anything bigger we use our mid system.
If you are interested please call so that we can discuss the scratch's.
The damage is normally not visable when installed
Myron c
