Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
SPEC clutches for the C6!
Old Jan 14, 2005 | 01:10 PM
tbyrne's Avatar
Default SPEC clutches for the C6!
We now have SPEC clutches available for the C6. They have done extensive testing and found that their flywheel is required for their clutch to function properly on the C6.
There are 5 stages available. Stage 3 tends to be the most popular -
Stage 1 - A Stage 1 clutch is a great upgrade from stock for street use and will hold 400 horsepower. Stage 1 clutches include a metal backed / organic faced disk.
Stage 2 - Stage 2 clutches are recommended for mildly upgraded vehicles with a power adder. A segmented Kevlar disk is used on the Stage 2 clutch kits.
Stage 3 - Stage 3 clutches come with a sprung center disk with pads. The disk pads are a carbon/ceramic combination, rated to 680 horsepower.
Stage 4 - Stage 4 clutches are not recommended for street use due to their aggressive nature. A rigid disk and carrier are used in combination with your choice of Kevlar, carbon or ceramic pads.
Stage 5 - Stage 5 High-clamp load pressure plate, iron disc, bearings and a tool.
ORDER LINE - 1-877-4-TBYRNE (1-508-636-0770 in MA)
E-MAIL - tbyrne@tbyrne.com
NEW WEEKLY SPECIALS CAN BE SEEN ON - OUR WEBSITE
