Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Aftermarket clutch question...
Old Feb 12, 2005 | 06:26 PM
TurboLs1's Avatar
Default Aftermarket clutch question...
Will the Spec stage 4 clutch kit from my '98 z28 work in a C5? Also, were the slave cylinders in the '01 C5's weak like the one in my '98 z28? I had to replace the one in my z28 when I installed the Spec pressure plate. Thanks for the input.
Old Feb 14, 2005 | 02:01 PM
TurboLs1's Avatar
Thanks for all the help but for future reference to help others...it appears that the clutch and PP will work in the Corvette and the '01 C5's had the upgraded slave as well so there is no need to upgrade to an aftermarket slave cylinder unless you want to.
