Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
16 Inch wheels besides ccw's for et streets.
Old 02-20-2005 | 02:26 PM
CraZee ZO6's Avatar
Default 16 Inch wheels besides ccw's for et streets.
Hey,
I need 16 Inch wheels besides ccw's for et streets! Is there anything else? I did some searches and couldnt find anything. Does WELD or anyone make anything that works for the corvettes? I just need rears.
Thanks for all the help guys..
-Zee
Old 02-20-2005 | 04:55 PM
baldurann's Avatar
Maybe F-Body tires would work?
Old 02-21-2005 | 09:50 AM
SPRSPT's Avatar
From what I have seen with any 16 inch wheel (even F/Body) you have to notch the control arms to get the rim to fit...17's will fit no prob. They do make 17 inch ET streets...
Old 02-21-2005 | 11:36 AM
fast 98 C5's Avatar
I think centerline makes one ?
Old 02-21-2005 | 03:18 PM
CRZY747's Avatar
Do you have an upgraded clutch and rear parts, and if so what all have you done to beef up the rear end ????
JET
doing a little work myself, similar setup
Old 02-21-2005 | 06:27 PM
fast 98 C5's Avatar
You can just by the CCW rears. I have the centerline wheel and you have to grind a little and hammer the ball joint cover a little, no big deal. I heard you have to even do that sometimes with the ccw's.
Old 02-21-2005 | 11:06 PM
butcher1's Avatar
Actually , you can't. John won't sell just rear wheels with ET Streets on them. If you want ET Streets , you have to buy the fronts too because it's too dangerous to run ET Streets rears with radial fronts.
Quick Reply: 16 Inch wheels besides ccw's for et streets.
