Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What tire and wheel combos are you using for C5's?
Old Apr 13, 2005 | 01:36 AM
Spellbound's Avatar
Default What tire and wheel combos are you using for C5's?
I have only heard of CCW's for vettes. Anything else out there?
Old Apr 13, 2005 | 06:28 AM
fast 98 C5's Avatar
race tires ?
Old Apr 13, 2005 | 08:41 PM
Spellbound's Avatar
Originally Posted by fast 98 C5
race tires ?
Sorry, yes, Drag Race.
Old Apr 14, 2005 | 02:14 PM
allthrottle&nobottle's Avatar
On the 97'..... 345/30/18 bfg drs on HRE 545 18 x 12s........cutting 1.52-1.55 all day long. Drive up, race, drive home
On the 00' vert.........275/35/18 bfg drs on 18 x 10.5 thin spoke repros cutting 1.72' 60's so far on 2 runs..... Drive up, race, drive home
They are not light weight, but I can drive 450+ miles on them w/o worry too!
Old Apr 18, 2005 | 07:19 PM
franny40's Avatar
for the Z huh. your car is as you know i have been using the nitto dr's 285/35/18
Old Apr 18, 2005 | 10:13 PM
CySevans's Avatar
Stock Z06 wheels and Toyo Proxes T1-S tires all around (stock sizes). Lost some dry traction, but gained a ton of wet weather performance.
Old Apr 19, 2005 | 07:26 PM
REDGAR's Avatar
CCW, www.ccwheel.com, makes a 16" wheel to fit the MT ET Street bias ply tire which is basically a DOT slick. However you have to buy the whole drag package.
MT also makes a 17" bias ply tire that can fit on z06 9.5" wheels. When running these with the radial front tires, the car will feel unstable up top and therefore not the safest combo but some have don this.
You can go to a drag radial you can fit on stock 17" 8.5 or 9.5 vette wheel. tire size is 275 45 17 and are available from BFG, MT ET Street Radial and Nitto.
You can also use a 17 x 11 zr-1 wheel with a 315 40 17 BFG or Nitto
You can also use stock 18" rear wheels with BFG 18" drag radial.
which one is right for you depends on how much power, how much drag racing and how much driving you want to do on them.
Old Apr 19, 2005 | 08:51 PM
Spellbound's Avatar
Thank you.
Old Apr 20, 2005 | 06:20 AM
That guy kinda sounds like he knows what he's talkin about...........He mostly does! Hey Edgar
Old Apr 20, 2005 | 08:10 PM
REDGAR's Avatar
I am happy to help.
Yes Steve I do have a 1 or 2 (thousand) passes under my 6 pt belts
