Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Yet another tech tip
Old Feb 28, 2002 | 09:40 PM
BlownC5's Avatar
Default Yet another tech tip
Hey everyone, got another tech tip for you. You may recall that I bought some used Crane 1.8 rockers awhile back. Well when I ran the valves, I didn't have a bump starter to crank the motor over and you don't have much room to work a breaker bar on the crank nut. Well, what I did was take a 24mm socket and machine 2 wrench flats on the end for a 1" long open ended wrench. Take your spark plugs out to ease crank rotation and it works great. This way you don't have to remove the steering rack to get at the crank nut. You can just barely slip the socket in with it still in place. Later <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
[ March 01, 2002: Message edited by: Jon C ]</p>
Old Mar 1, 2002 | 05:17 PM
Godspeed's Avatar
Default Re: Yet another tech tip
Thanks for the tip. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
-Jeremy
