Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Just lowered the C5
Old Mar 9, 2002 | 06:51 PM
06C6FVR's Avatar
Default Just lowered the C5
Wasnt as hard as i expected, and the car looks great. I will post some pics soon. Its about 1"lower in the rear and around 3/4 of an inch lower in the front
Daren
Old Mar 9, 2002 | 09:03 PM
jmX's Avatar
jmX
Default Re: Just lowered the C5
If you cut the bushings down a bit you can get it slammmmed.
http://jmx.car-audio.net/c5/sideshot.jpg
Old Mar 9, 2002 | 11:29 PM
BlownC5's Avatar
Did it change the ride characteristics?
Old Mar 10, 2002 | 04:45 AM
06C6FVR's Avatar
Yes, the ride characteristic changed, and i must say, much for the worse. Im gonna prolly put the bushings back in. It rides very bumpy in the rear. Front is not too bad, but rear sucks
Daren
Old Mar 12, 2002 | 11:27 AM
Visceral's Avatar
likely because your shocks are bottoming out.
In jmX's car above, the car did not bottom out at all because Bilstein Sports were installed. They are designed to accomodate for lowering.
I might recommend s set of Billstein sports from a www.corvetteforum.com mall vendor thats also a sponsor here...
\chris
Old Mar 12, 2002 | 11:33 AM
97C5ENVY's Avatar
Even with Bilstiens if you go past 1" you'll have the same "bumpy" rear. The only solution if you go beyond 1" is to cut some of the bump-stopper off of each rear shock. This will give the shock more travel thus smoothing out the ride in the rear.
Old Mar 13, 2002 | 12:37 AM
06C6FVR's Avatar
Well, i put one of the bushings back in, still have one out, and the car rides MUCH better. Just like stock. It is now lowered about 1/2 inch. Still looks good, and no more bounce <img src="gr_stretch.gif" border="0">
Daren
Old Mar 15, 2002 | 01:24 AM
BlownC5's Avatar
I might go for 1/2" myself if the ride quality is close. I installed those Hotchkiss sway bars and the difference is amazing!
