Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
How to cure wheel hop?
Old Jan 22, 2003 | 11:21 PM
jmX's Avatar
jmX
Default How to cure wheel hop?
I'm guessing there's probably no way to fix the wheel hop in these cars but I might as well ask.
Tonight I went to the track, I launch at idle, and right around 5000rpms the tires would just totally let loose in first gear and the rear of the car was hopping BAD. It setoff my ABS/TCS/AH codes telling me to service all 3 systems after the run, and my radar detector was thrown from the windsheild at me as it was so violent.
I'm running standard 18" wheels with street tires. Does lower tire pressure help? Any alignment settings that could reduce wheel hop? The problem also happens a lot when its wet outside, pretty much whenever I dont have traction.
Old Jan 23, 2003 | 11:01 AM
66ImpalaLT1's Avatar
Default Re: How to cure wheel hop?
A z06 alignment helped my wheelhop problem. It wasnt too far off from stock, but enough to cause wheel hop.
Eric
Old Jan 23, 2003 | 11:02 AM
Ling_650vette's Avatar
maybe running a lower psi will help, what about a set of coilovers? thats the only thing i can really think of. Cant do some of the other stuff like subframes, lower control arms and all that...maybe coils and/or a lower psi will help? only one way to find out...
Old Jan 29, 2003 | 10:21 AM
c5ls1vette's Avatar
A buddy of mine had a real bad wheel hop in his c4 corvette which is running 11.40's. He eliminated it by switching to the QA1 adjustable shocks. Just my 2 cents.
Old Jan 29, 2003 | 10:25 AM
c5ls1vette's Avatar
Oh by the way, thanks for your write-up of the cam install in the vette, I will be using it to help me out in the next couple of weeks.
Old Feb 2, 2003 | 01:16 AM
Chubby's Avatar
I went with the touring suspension on mine, hoping it would allow for more *** end squat on launch, still hops. BTW the 01 Z I drove hopped as bad or worse.
Greg
Old Feb 2, 2003 | 02:53 AM
Speaking of squat, thats the one reason I havent changed my shocks/springs yet. Right now my car squats then blows the tires away. Since I installed the like lock I cured that, at the expense of my clutch.
I'm hoping for 11's in '03, if I can get traction. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Eric
Old Feb 2, 2003 | 08:57 AM
swtvictory's Avatar
I know this does not seem logical.. But I had wheelhop with my 18's when I had the vette rims.
Of course it wasdecreased a LOT with the $1,000 suspension "BMR Trak Pak" but it was still there.
Went back to stock rims and its TOTALLY gone.
Its the size of the rims.. If you want to buy smaller ones just for the track "Some sort of drag welds maybe?", that will totally cure it
Old Feb 13, 2003 | 08:29 PM
McRat's Avatar
I had violent wheelhop on the 1-2 shift until I switched to ET Streets. ZERO HOP. None.
