Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Z-06 Gear swap question?
Old Mar 17, 2003 | 08:06 PM
Nautilus's Avatar
Default Z-06 Gear swap question?
What do I need to do to put lower gears in an '02 Z-06? I want to go to 3.73's. Can I just buy a gear package or do I need a whole new diff? I have been told I need a whole new diff, if that is true than could someone explain why? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Thanks, Tim.
Old Mar 18, 2003 | 06:57 AM
Ling_650vette's Avatar
Default Re: Z-06 Gear swap question?
You should just need to buy a gear package, because the IRS systems are pretty strong, so you wouldnt really need to replace anything in that respect, but it probably wouldnt hurt to strengthen up the u-joints or half shafts.
Old Mar 18, 2003 | 05:29 PM
Nautilus's Avatar
Can anyone else tell me for sure? I don't want to just order the gears if they wont work. I thought they would but I was told I need a new diff housing too? Has anyone here swapped gears in a Z-06?
Old Mar 18, 2003 | 05:48 PM
66ImpalaLT1's Avatar
I would not do your own gears. I'd get them installed professionally by a shop who has done them before.
C5 gears are different than the f-body, and require special tools.
Eric
Old Mar 18, 2003 | 06:17 PM
1badvet's Avatar
I'm not sure going from 3:15 to 3:73 but when swapping from 2:73 to 3:42 you need new carriers with the gears. I think this would be worth checking into. It ended up being cheaper for me to just purchase the new unit however with the price of a 3:73 being almost or double the cost of the 3:42 unit it seems worth doing the gear swap.
Old Mar 18, 2003 | 08:56 PM
Oh yeah, 66Impala, i wasnt refering him do the gears himself, but thanks for that, it'll save him a world of headache relief
Old Mar 21, 2003 | 08:18 PM
Mike Mercury's Avatar
I swapped out my factory 3.15 for a new 3.42 unit myself. Was time consuming but not that challenging.
read about it here:
mikemercury.home.att.net/342.htm
Old Mar 21, 2003 | 10:20 PM
Let me clarify my prior comment. I will be installing gears this spring as Mike has done, but I wont just buy a ring and pinion and try to set them up in the housing.
I'm going to send my diff out to be rebuilt at East Coast Supercharging.
Eric
Old Mar 22, 2003 | 09:09 AM
Nautilus's Avatar
I gave up, I'm just going to drop the car off at East Side Performance in Wallingford, CT and have them do the whole diff. But thanks for your help.
Old Mar 28, 2003 | 10:17 PM
SOCIAL ENGINEER's Avatar
4.10's all the way, had CARTEK put them in for me ... I'm launching at 5500 rpm, with stock output shaft. Last year, I heard they are exclusive and hard to get - but, by now I am sure it's an easy ring and pinion swap, any half way intelligent person can figure out. Doing it on a C5 is a bit more tricky, since you have to drop a lot of sh*t from the rear of the car <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
