Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Rear Diff question
Old Jun 24, 2005 | 06:53 AM
PA Z06's Avatar
Default Rear Diff question
Going to change my rear Diff oil this w/e, I already bought the recommended additive from GM, not sure which weight royal purple I should run, and does anyone how much it holds.
Thanks in advance
Old Jun 24, 2005 | 09:01 AM
XTrooper's Avatar
Thanks in advance
First, I would recommend you use the regular GM gear oil, but if you're going to use Royal Purple, I'd get the 75W90 or 80W90 depending on how much abuse your rear sees. If you go to the drag strip a lot, I'd use the 80W90. It will take slightly less than two bottles (2 quarts).
Old Jun 24, 2005 | 09:35 AM
Assassin's Avatar
DONT buy royal purple, everybody that I've talked to that has NEVER used it says it works great, every body that I know that races say's they've blown **** up w/ royal purple, I've seen it happen, I would get the gm gear oil if I were you, and for any additives lucas IS the best!.... happy fluid changeing....
Old Jun 27, 2005 | 05:46 AM
PA Z06's Avatar
Thanks for the input guys, Im probably gonna just stick with the GM gear oil then.
Old Jun 28, 2005 | 12:31 AM
Dan_the_C5_Man's Avatar
Redline makes great stuff. All that DTE in Indiana uses. Good enough for them, good enough for me!
Old Jun 28, 2005 | 06:53 AM
PA Z06's Avatar
Thumbs down
what about Mobil ! gear oils
Old Jun 28, 2005 | 08:31 AM
slo-vette's Avatar
Another vote for the Redline gear oil.
Old Jun 28, 2005 | 11:50 AM
PA Z06's Avatar
what weight 75w90
Old Jun 28, 2005 | 04:34 PM
slo-vette's Avatar
what weight 75w90
Yes 75w90 with the limited-slip friction modifier.
Old Jun 28, 2005 | 05:41 PM
SideStep's Avatar
I agree....
Old Jun 28, 2005 | 07:38 PM
BadMonkey's Avatar
just use teh GM stuff your not gonna see much of a gain. Synthetic gear oils from what I understand do not work well with our rears. But i honestly do not know. But since I blew my rear end sky high recently I will be adding some gear oil myself ANd a new rear end
