C5 Active Handling and Traction Control
thanks
My car (2000 C5) has the 1st generation A/H. I have heard that the 2nd generation A/H allows a little more freedom. Still I wouldn’t want it. For the most part it’s just a Band-Aid for poor driving skills.
The first gen AH was not as good as the 2nd gen AH..but if you are a very good driver either AH will hinder your high performance driving technique..
Also, seems to me unless you really mess up, AH will save it. All my experience with AH is speeds under 50. not sure how it responds in the high speed stuff like 100 plus.... I'd guess just fine though
Anyone know if you can update 1st gen to 2nd? Only software or is there additional hardware in gen 2?
oh, also found that I really don't care for the traction control - just seems to slow you down way too much... just use your foot...
also also, I've only had AH kick in during oversteer conditions - not sure how it performs in understeer conditions
Push the button on the consol it will turn it off
The problem is that if you are very used to driving without A/H, when it activates it can counter your learned corrective inputs and actually cause you to wreck, because the car is behaving in a different manner due to the A/H, and your learned, ingrained responses are now incorrect. With a lot of practice I’m sure you could relearn how to drive with A/H, but then if you drove any car without A/H you would not be able to handle it correctly.
