Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
fuel gauges
Old Nov 19, 2005 | 03:41 PM
TigerSharkVette's Avatar
Default fuel gauges
earlier today i was driving around and i had 3/4's of a tank then all of a sudden the low fuel came on and beeped then the manuel gauge went all the way down to, so i put $10 in and it weent back up to a full tank anyone know why it would do this
Old Nov 19, 2005 | 08:07 PM
H-5-L's Avatar
Theres 2 saddle tanks on the c5,a syhon pump moves the fuel from tank to tank to keep the car balanced while cornering.(condensed version)There is sulfer in todays gas,it gunks up the parts in the tank and gives false readings.Some folks take there car in under warranty,and they change the parts out,(temp solution),theres also a gm "flash" they will do to the PCM to mask the problem.Not good if you have a custom tune,you'll lose it.
Now,i had the same problem as you,4 years ago.I was recommended by a local GM mechanic (friend),to pour a can of BB44K in the tank.I never had the problem again.I add a can every 6 months,it's stronger than GM top end cleaner,and way stronger than a bottle of techron,only use every 5,000 miles.It also makes the cars idle purr,cleans the combustion chambers,and the entire fuel system,try it,you'll be a happy camper.
Old Nov 19, 2005 | 09:31 PM
Nautilus's Avatar
I've had the same thing happen to me twice... What is "BB44K"..?
Old Nov 19, 2005 | 11:31 PM
H-5-L's Avatar
It's a fuel system cleaner,stronger than GM products.It's about 16 bucks a can.I get mine from the Chevron station.
Old Nov 20, 2005 | 01:13 AM
2MuchRiceMakesMeSick's Avatar
16 bucks a can.
Old Nov 20, 2005 | 01:22 AM
H-5-L's Avatar
Originally Posted by 2MuchRiceMakesMeSick
16 bucks a can.
It's worth it....it's not a snake oil,it really works.On another vette site DC.com,their's many that are now believers.Even the guy that had his tank parts changed out twice,now his warranty is up..It's about a $500 job from the dealer.$16 doesn't sound to bad compaired to that.
Old Nov 20, 2005 | 02:40 PM
thanks can you get it at like pep boys or autozone or something like that
Old Nov 20, 2005 | 04:00 PM
Lost's Avatar
Berryman B-12 works and it costs less than $3 a can. If you don't think its potent, spill some on your car and watch your paint disappear.Oh, its a common problem on these cars caused by a sulphur build up from cheap gasoline on the contacts of the fuel sending units.
Old Nov 20, 2005 | 05:53 PM
Nautilus's Avatar
Thanks I'm going to try it out
Old Nov 21, 2005 | 04:56 AM
Snake oil... that was my first though.
Im going to get a can and try it out.
Thanks for the tip.
Old Nov 21, 2005 | 07:46 AM
H-5-L's Avatar
Thanks for the tip.
I hear ya bro...I'm so not a believer in many snake oil products..someone said it's about 10 bucks at walmart,but out here,our walmarts don't have the stuff.
For the record..i'm not affiliated with this product..just an customer.
