Long tubes or bigger cam?
Well,...you need them both man. But,..Since you already have DECENT headers,...i'd lean more towards the cam. Just keep in mind your gonna have to have the car tuned for the cam.
My next mod, would probably be the long tubes and X-pipe after the cam
J
edit: i take it back..not a waste of money in general..you DID get 398whp. But it would have cost just a tiny bit more for LT's and the same for a better cam.
Now the F13 is the best streetable power making cam out there in my opinion.
If i were you i do a cam bc you i wouldnt guess you would see more then 10-15 rwhp taking thoes shorties off and putting on some LTs.
Ya but his was tuned @ Synergy which is a Dynapak which usually shows 10% more than a roller dyno. So these numbers can't really be compared.
I personally know someone who went from a Dynapak to a Mustang dyno numbers went from 740whp to 670whp same setup
Another thing to consider is that with a bigger size cam youll need a tune. To take full advantage of that tune I would recommend headers first.
But I guess if it's one or the other... like if you get headers you will never be able to get a bigger cam then I'd say go with the cam. If you think you can get headers and put the cam next on the list then do that!
