Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
99 Vette climate control problem. Need help
Old Dec 30, 2005 | 10:14 PM
Jeff 97 Formula's Avatar
Default 99 Vette climate control problem. Need help
I noticed on my dad's 99 vette that no matter where the **** is positioned for the passenger temperature, it's always blowing hot air on the passenger side. I'm also hearing a clicking noise anytime the ignition is on (engine on or off). I assume one has something to do with the other. Any ideas on how to fix? Thanks.
I just hope this is not the
Old Dec 31, 2005 | 10:29 AM
cam75w/ls1's Avatar
You have an electric door control motor that has stripped out and the teeth are clicking.
Old Dec 31, 2005 | 03:20 PM
Any ideas on getting to these parts?
Old Dec 31, 2005 | 09:52 PM
cam75w/ls1's Avatar
What you could do is take the cover off the bottom of the dash on the passenger side and see where the clicking is coming from. The control door for the climate control is in the heater-a/c box. Usually has two or three screws and a connector. I did one about 4 years ago and don't remember specifically. When I go to work monday I'll look on my alldata and get specifics for you if interested.
