If anyone doubts what TPiS said about the 1 3/4" headers, then read the latest copy of Engine Masters. The top dog was making way over 600 HP with some beat up, dented up 1 3/4" headers.
I'd like to see the test and results done............say in an upcoming issue of HPGM or something. But even if the TPIS's do make more power (which I doubt), how easy do they fit? I've heard nothing but good things about the instalation of LG's Headers.
i have TPIS and will stand by them 100%. they were a breeze to install. put the car on a lift and pulled it back off in 2 hours. finish on them is excellent, AIR tubes lined up perfect. for the price, i would never change. even if lg's make more power, can you justify spending that much more money? nothing against lg, or any other maker for that matter, i am just stating the extreme luck i had putting my TPIS on!
would a stock cube blown (500-550rwhp) car benifit from the 1 7/8''?
i would say yes and no...might hurt you a little down low, but make it up in the upper rpms. i would invest in a good set of heads before doing a header swap.
That's cool, and I respect that. So are you saying the headers are easy to install, or are you saying you got lucky and your install was easy? I agree that the LG headers are over priced, but the finish is great and they are high quality! I still don't think that justifies the price. But the Vette community still pays for them.........I did! But do the TPIS headers come with an X-pipe, or do you have to buy one after you get there headers? Most Vette headers come with the X-pipe, but I just wanted to throw that out there.
Our TPIS headers have been tested against the LG long tubes by a GM engineer and we out performed the LG's by 7 to 10 hp. I have made over 660 hp NA on our dyno on pump 93 octane with our header. Our's header was the first on the market for the C5. You will find that a 1 3/4 header with the proper collector and h-pipe will outperform a 1 7/8 set every time.
Myron Cottrell pres TPIS
Correct me if i'm wrong, but if I recall the test correctly the TPIS header did not make more power than the LG's til around 8000 rpm . The LG was up 20 ft.lbs around 3000 rpm or so.
See our web site. look on the top of the front page. tpis.com
