2000 C5 Bone Stock Dyno
311rwhp, 326rwtq
Not bad!
It was from California. I live in Eugene, OR. No emissions...... I just put that there to show how much MORE restrictions are in it. Next dyno sheet will be with my 150 wet shot up and going, 160 t-stat, Vararam, Torquer V.2 cam, and a PCM tune from Texas-Speed. Should be a lil bit better.
But thanks for the comments guys!
Gonna do it, depending on how much of a pain in the *** it is. In 2 months I plan on getting LT's anyways.
If you note along the top of the graph it's a Dynojet, these are non load bearing dyno's and generally giver higher numbers compared to manufacture numbers. Plus it also says "uncorrected" which means these arn't SAE numbers. The "graph smoothing" grade will also effect the numbers.
If you converted them to what a load bearing dyno would generate (Mustang Dyno or Dynodynamics, or Rototest) and corrected to SAE your car would be some where between 290-300rwhp which is BANG on where it should be.
As I say nice numbers, and I only offer this explanation as others have commented on it being 'strong' for a Corvette.
So while it may not be "strong" for an LS1 it does show that the motor is healthy which is what I wanted to know anyways.
Trap speed > Dyno numbers anyways
