C5 Z06 question
Trans Am WS6 - 3,477 lbs.
That's good for approximately a .3 advantage in the quarter mile.
I'm not sure that just exactly how that translates into hp, but I would guess you are going to need a good 30 rwhp more than he has just to keep up. Be careful though if he gets any mods, a set of LG Longtubes will add +30 rwhp alone to the Z06.
Currently with 392 rwhp, I give the advantage to the Firebird. Also one factor is I have a hardtop Formula with low options which is also the lightest of the 4th gen Fbods I believe.
I also liked the HUD
The difference between the 01 and the 02 is
LS6 engine (Z06 model) receives 20 horsepower increase, to 405 hp, and receives 15 foot pounds more torque for a total of 400 lbs. ft. of torque
Pre-cat deletion
Revised rear shock valving
Aluminum front and rear stabilizer bar links
Aluminum transmission cooler case
Magnesium wheels no longer available (coupe and convertible)
Z06 wheels are now cast aluminum, not forged aluminum
Head-Up Display (HUD) now standard
Cam/Valve/Spring change
Electron Blue exterior color
Let us know the outcome of the race when it happens.
