Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
10sec. FRC C5???
Old Feb 5, 2006 | 05:06 PM
slow6.0's Avatar
Default 10sec. FRC C5???
what combination would it take for a stock bottom end 99-00 FRC car to make it to the tens. i am looking into buying one and i want to get some feedback from owners on what the best setup would be to accomplish this. I know a lot of guys are gonna say either turbo of blower but has anyone done it with heads/cam and nitrous and if so how long did it live. Any info would be appreciated
Old Feb 6, 2006 | 07:13 AM
V-seriesTech's Avatar
It can be easily done with heads/cam/full exhaust...and gears. Don't forget the tires ofcourse.
You can do it alone on nitrous to be honest but, theres nothing like the added power and how the car drives after a cam or heads and cam install.
list...
vararam. and air bridge
heads/cam or cam only
LS6 or fast intake
long tubes, probably LG's since your gonna stay at stock cubic inch
x pipe
catback
DTE stage III diff and rear strut brace
TNT F1 kit or direct port
tires.
....and last but not least,....a good custom dyno tune.
Old Feb 6, 2006 | 10:08 AM
CarsRFun's Avatar
^dont forget clutch
Old Feb 6, 2006 | 10:52 AM
Originally Posted by CarsRFun
^dont forget clutch
true. Probably should be the first mod after tires. Which should be your first mod.
Make sure its a good clutch as well,...we don't want what happened to my car, to happen to any of yours.
Old Feb 6, 2006 | 03:53 PM
usenterprise's Avatar
Default 10 sec vette
i have a 99 c5 conv it ran 13.40 at 106 stock drag radials 3000 stall catback and 150 shot nos ran 10.96 at 122.85
Old Feb 6, 2006 | 09:36 PM
slow6.0's Avatar
Make sure its a good clutch as well,...we don't want what happened to my car, to happen to any of yours.[/QUOTE]
Very true. i was actually thinking about a spec clutch until i saw the aftermath of your unfortunate experience with one. thanks for the info and good luck with your car hope everything works out for you
Old Feb 7, 2006 | 02:19 AM
STEALTH TURBO C5's Avatar
Cartek has had several stock bottom end Heads/cam 346cid C5's running from 10.50 to 10.99 ,they were running tens back in late 2003 , give them a call and talk to Dave , 908-317-4496 .
Old Feb 7, 2006 | 12:56 PM
PurpleHaze98's Avatar
grab yourself some drag shocks while your at it. I was planning ondoing the same thing but plans change.
Old Feb 7, 2006 | 06:45 PM
slow6.0's Avatar
thanks for the info i will for sure give them a call and see what they can do for me
Old Feb 8, 2006 | 12:01 AM
Chicago Crew UnderBoss's Avatar
A complete ECS Novi Supercharger kit will get you there no problem with bolts on, etc., as 600 rwhp is a no brainer on a stock engine at 10 lbs of boost!
Old Feb 8, 2006 | 12:17 AM
zo6vetteman2003's Avatar
Too much boost with the stock bottom end. Stage II procharger with 6 psi. of boost would be 530rwhp definitely in the tens. You would definitely need some tires. I have Nitto's on mine what a difference launching.
Old Feb 9, 2006 | 06:58 PM
robz*'s Avatar
Heads and Cam N/A will do it. Just use a reputable tuner that knows how to build and tune the car for the track.(like CARTEK). I have run 10.9x's CAM-only over a dozen times with a Cartek setup. With thier latest Heads/Cam packages we will likely see some low 10.4x's N/A . And that's from a full weight street car that can be an everyday driver. No stripped down track car!
Old Feb 10, 2006 | 10:22 PM
slow6.0's Avatar
WOW!! that is impressive. It sounds like Cartek is defenitly the company to go with if you are going N/A. Just think 10.8x N/A and then possibly a little nitrous on top of that.......... that would be insane.I cant stop smiling right now just thinking about it.
