Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Rocker Arms
Old Mar 2, 2006 | 02:11 AM
c5_ls1_6spd's Avatar
Default Rocker Arms
would it be ok for me to run 1.8 rockers on my '02 c5 LS1 with stock cam and springs?
Old Mar 2, 2006 | 03:14 AM
NOSjohn's Avatar
Restricted User
The stock '02 C5 cam specs are: .479 intake / .467 exh., if you divide that by 1.7 (stock rocker ratio) it gives you a base lift of .282 / .275. You then multiply those base numbers by the new ratio (in this case 1.8) and you get ~.508 / .495 ...and in this case, it puts you at numbers for the stock 2000 C5 cam, which should be safe depending on the current miles on your car.
Just to be safe, you could always pick up a set of yellow GM LS6 springs direct from GM for less than $80. I've seen them some places for under $60.
You could also call a place like Cartek or LG Motorsports and ask them the same question. It's 4 a.m. and I'm not exactly wide awake.
Old Mar 3, 2006 | 08:54 AM
Kraest's Avatar
There's really no point in doing that. I'm still using stock rockers in my setup.
Old Mar 3, 2006 | 09:11 AM
David Gordon's Avatar
We installed a set of SLPs 1.8 rockers on my friend 2001 TA and gained almost 25 rwhp. All we did was swap the rockers nothing else.
Old Mar 3, 2006 | 11:01 AM
Kraest's Avatar
I find it very hard to believe that you would gain 25 FLYWHEEL horsepower with a rocker change, let alone 25 rwhp.... Anyone else had similar results?
Mike
Old Mar 3, 2006 | 11:28 AM
NOSjohn's Avatar
Restricted User
It's possible. We gained 13rwhp from a simple bolt-on Halltech CAI and 18rwhp from a RAPTOR CAI...why not 25 from a rocker swap?
A similar example is the LS1 motor to the LS6 motor...the only main power making differences between the two, realistically, is the cam and heads. How much more power does the LS6 make versus the LS1?
With a good tune and almost 25 thousandths increase in lift, I would say 20-25rwhp is possible.
Old Mar 3, 2006 | 02:11 PM
His car was an auto. 01 TA with exhast and a lid. Dynoed it made 320rwhp after the change it made 345 rwhp.
Old Mar 3, 2006 | 02:48 PM
did it have longtubes?
Old Mar 3, 2006 | 03:28 PM
I honestly cant remember if this was before or after the headers.
