Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
99 C5 Clutch Install
Old Mar 24, 2006 | 12:56 AM
2xLS1's Avatar
Default 99 C5 Clutch Install
Any tips or where to look for a how to? It doesn't look fun. What is an average labor charge for a clutch install?
Old Mar 24, 2006 | 01:07 AM
NOSjohn's Avatar
Restricted User
Check LS1howto.com and Google it. I saw another person complete a write up on his experience in doing one from the ground with just floor jacks and jack stands. It can be done but is very tedious and quite a bit of work for the DIY driveway mechanic. I REALLY suggest using a lift.
I've done quite a few and 3-4 hours is not uncommon. I think book time at a dealer is probably 4-5 hours. Good luck with what you choose. Are you moving up to the LS7 clutch ?
Old Mar 24, 2006 | 01:09 AM
Mike94ZLT1's Avatar
http://fear.net/~dope/c5_clutch_install_pics.html
http://vetteweb.com/tech/vemp_0506_clutch/index.html
http://www.cajundude.com/differential.htm
Old Mar 24, 2006 | 01:17 AM
CrazyChris's Avatar
It's not fun at all but a good learning experience! The write ups posted above are a great reference.
Old Mar 24, 2006 | 06:18 AM
V-seriesTech's Avatar
The job sucks....for the record.
It isn't rocket science but,..it's involved for a friggin' clutch swap.
Old Mar 24, 2006 | 06:43 AM
jocko's Avatar
i have step by step instructions from gm,transmission along with torque tube and diff come out so rear suspension carrier has to come out also.
Old Mar 24, 2006 | 09:49 AM
2xLS1's Avatar
Thanks. Those write up will help a lot. We will be using a lift and I think the guy is going to go with Spec 3. Not my car so I'm not picking the clutch.
Old Mar 25, 2006 | 09:57 PM
hennesseycpl's Avatar
hey guys good luck with that clutch i think its a a spec2 + i cant wait to get my car back you guys do great work
