Vibration - Clutch/ Engine???
I've also just put on LG LT and haven't had a chance to get a dyno tune, so I don't know if that would have anything to do with it. Any suggestions
Ranger
I don't think I've seen you on this board before?
(Remember you from Z06vette.com)
-N
I haven't read or heard of any Z06 stock clutch coming apart. So wouldn't worry about that.
Bad vibration sometimes occurs after a clutch swap where the new parts are out of balance or improperly installed (index of the flywheel lost, for example). But from your description, the vibration you have seems minimal.
And Hi Nautilus, expect I'll be more active here than before.
Ranger
I learned way more than I ever sought to know when a tech lost the index point on my 2001 Z06 when he remove the flywheel WITHOUT marking a scribe to the crank. The new clutch and two more vibrated badly enough to knock out your fillings.
The end result was two field engineers from Chevy powertrain dispatched to the dealer to rebalance my engine using specializedd equipment. They got it right. But the car was done for 24 days. The root cause was the lost index of the FW.
Ranger
