Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
weight difference between FRC and coupe
Old Apr 2, 2006 | 02:03 PM
vetred's Avatar
Well,.....actually,.....eh,...in 99 there was a limited number of F.R.C.s manufactured called the,.....Z-51 lightweight???? Nope,.....I dont have a clue what they were but, its in the books! OH, ....so I called a budy of mine (real 40 year vet guy!) and he says it was to incourage people to go racing with the "new" Vetts. Most of them were down to the bone! No old guy ride controle, old guy seats or eletronics! DAMNIFINO!
Old Apr 2, 2006 | 02:33 PM
jargan04's Avatar
The no option FRC's were the lightest before the Z06 came out. It had to be the base option car, no dual zone, no hud, no bose, no active handleing.
Old Apr 3, 2006 | 05:51 AM
H-5-L's Avatar
The zo6 has thinner glass too,does the FRC?I believe this is why the zo6 has no option for the windshield antenna.
Old Apr 3, 2006 | 10:17 AM
FL Zinc's Avatar
Originally Posted by c5_ls1_6spd
i agree. i went to the track last night w/ under 1/4 tank of gas and the results were terrible. i was cutting 2.5s and 2.6s all night. i guess from now on ill be going to the track with over 1/2 tank of gas.
2.5 and 2.6 60's? That has nothing to do with how much gas was in your tank, that's a textbook example of the driver delete mod.
Old Apr 3, 2006 | 11:06 AM
HolyShiznit's Avatar
Uhh....ya. Any FWD will pull better 60's than that.
Old Apr 4, 2006 | 11:03 PM
c5_ls1_6spd's Avatar
w/ the same tires but a 1/2 tank of gas i was cutting 2.1s on a different day. unless the day i was cutting 2.0s the track prep was shitty.
Old Apr 4, 2006 | 11:48 PM
It's almost a physical impossibility that roughly 20-30 lbs of gasoline drove your 60's up .5 to .6 points. Not trying to jump on you but that is quite the outlandish claim.
Old Apr 5, 2006 | 01:07 AM
FACE's Avatar
I believe you answered your own question...
Old Apr 5, 2006 | 05:37 AM
2.73 Vette's Avatar
With the coupes depending on options your talking 3230-3310 pounds.
If you have an auto C5 with every last option Your looking at 3280 pounds. Then dont forget that many mags weighed the coupe c5 with the extra targa roof in the back trunk the way it came from the factory. Thats an extra 30 pounds bringing the total to 3310 pounds with a full tank of gas...
Take that same factory 3310 pound C5 coupe to the track with a 1/4 tank of gas and the extra roof sitting in your garage and your driving a 3230 pound vette.
Take off the targa top and now that same 3310 pound Coupe that turned into a 3230 pound car by only having a 1/4 tank of gas and no extra roof in the back trunk is a 3200 pound Vette with the arodynamics of a truck ( but it's still light for arguments sake)
But to be totaly honest Id rather have the 3260 pound coupe than the 3160 pound FRC.
Yes the 100 pounds is an advantage at the strip. But the .29 drag for the coupe vrs the .32 drag for the FRC is an advantage on the highway rolls for the coupe..
Pretty easy to make your car loose weight. Changing the arodynamic drag rating is a little nore tricky.
I wouldnt be surpised if my car weighed in at 31xx pounds right now.
-ls6 heads ( lighter than ls1) I forget weight savings
-borla straight pipe exhaust (lighter than stock cat back) 20 pounds weight savings
-straight pipes( lighter than factory cats) 10 pounds weight savings
-removed tire sensors ..not sure about the weight savings
Old Apr 5, 2006 | 12:39 PM
A very LARGE and important weight savings is stock run-flats versus just about any other tire. You can save nearly 15lbs of unsprung weight by having all four tires changed from those horrible things, not to mention your Corvette will handle a million times better.
Old Apr 5, 2006 | 01:29 PM
Cgillies86's Avatar
I think one reason corvettes dyno alittle lower than the f-bodys is partially due to the runflats. Also, the corvette has rear rotors on the rear than the f-body.
