Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
corvette skinnies
Old Apr 5, 2006 | 03:46 PM
c5_ls1_6spd's Avatar
Default corvette skinnies
where can i find corvette skinnies for my front wheels? i want to order some but don't knoiw where to find them.
Old Apr 5, 2006 | 04:05 PM
chad@xtreme's Avatar
CCWs makes skinnies.
Chad
Old Apr 5, 2006 | 04:08 PM
REDGAR's Avatar
www.ccwheel.com
Old Apr 5, 2006 | 04:24 PM
does jegs sell skinnies that'll fit a c5?
Old Apr 5, 2006 | 05:02 PM
WayneE's Avatar
Third for CCWs
I don't think you'll find a standard 15" skinny from Jegs/Summit that will fit a C5. The CCWs are 16s.
Old Apr 6, 2006 | 03:19 AM
CrazyChris's Avatar
Pretty sure you can fit a 15" up front but no way in the back. Those CCW pics you posted are awesome!
Old Apr 6, 2006 | 07:51 AM
REDGAR's Avatar
Forum member GTFORMULA got 15" to fit fit after some surgery seen here https://ls1tech.com/forums/corvette-performance/465553-will-15-inch-wheels-fit.html
I've not seen anyone get a 15 on there without changing the rear but you can get a 16 in there there with little moding of upper ball joint and then you have an option of using 16" fbody wheels.
Old Apr 6, 2006 | 11:02 AM
PurpleHaze98's Avatar
damn i would love to run welds prostars on my car i think it would look too tough
Old Apr 6, 2006 | 12:42 PM
REDGAR's Avatar
I put 15" front Bogarts on mine using the Strange Engineering drag brakes.
See pic and make sure your browser is not fitting it to the window so you get the full view
http://corvettechallenge.info/cpg133...s/P3170060.JPG
Old Apr 6, 2006 | 01:10 PM
WayneE's Avatar
That looks great. Does Bogart make a 16" skinnie?
No offense to GTFORMULA, but that grinding is not safe. He's taken at least 1/2 the caliper material off, at what looks to be a critical area. I'd love to see him mic that area. I can pull a wheel/caliper and mic my stockers for comparison.
IMO, extremely dangerous way to get skinnies on the front. Save that .10 or so and get new calipers/run full size wheels until you can save enough money to do it right.
Old Apr 6, 2006 | 01:30 PM
REDGAR's Avatar
I don't know if they make a 16" skinny. they do not make a C5 specific set of 16" rears either. these are an almost fit in the rear with help of a centric ring in the center
Old Apr 7, 2006 | 11:44 AM
itsfast's Avatar
If you want to go a cheaper route, I hear that the new GTO spare wheels also work, but you may want to replace the tire with a higher speed rated radial.
Old Apr 7, 2006 | 02:37 PM
usd2sing's Avatar
got any ideas where to find a 17in x 4in tire that would fit??? or maybe 5in???
GTO spares are 17x4. u can get them for under $100 ea. prob is finding a tire to fit..i'd pull the trigger on these if i could fing the right shoe to fit them.
