Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Heads/Cam/LongTubes Install DONE!!!
Old Apr 13, 2006 | 04:40 AM
Vettish's Avatar
Did you get connection pipes or did you just use the cutouts or both??
Old Apr 13, 2006 | 06:28 AM
serendipity's Avatar
Looks and sounds good! I'm getting a Futral F13 put in my 06 the first week of May. I hope it sounds as good as yours. I'm looking for something daily-drivable, but that you can tell is cammed. Sounds like you found that. The Torquer v2 and the F13 are somewhat similar. Post up after you tune/dyno it
Old Apr 13, 2006 | 10:34 AM
HolyShiznit's Avatar
I have connection pipes but they are reducers, so you can't really put cutouts on them. I bought two 2.5" cut-outs from TSP and had them welded onto the H pipe. I measured and cut everything so it would fit nicely. Basically the cutouts slip fit into the connection pipes.
Thanks for the comments guys.
WARNING: This has very MINIMAL ground clearance, a lowered vette would get high centered with my set-up. I am still working through issues with the cutouts so be warned.
Old May 17, 2006 | 08:52 PM
slvrblt's Avatar
Do the cutouts cause the ground clearance problems or are the long tubes more to blame?
Old May 17, 2006 | 11:23 PM
I had to take out the cutouts, ended up hitting something on the road that absolutely ruined one and almost destroyed the other. Sucks because I lost 200 bucks on those cutouts (shipping/install/welding/etc), and only had them on for two days. The long tubes have EXCELLENT ground clearance!
Old May 18, 2006 | 10:26 AM
voda1's Avatar
Dip stick tube #12563817 used from 2001 up
Old May 18, 2006 | 05:25 PM
slvrblt's Avatar
Thanks for the quick response!
Is there any way to install cutouts on these cars that does not cause ground clearance issues?
Old May 18, 2006 | 06:31 PM
cantdrv65's Avatar
Post
Yep. I have a 2001 Z06 and the dipstick bolts to the head. On the O2 issues I had to loosen my passenger header (TPIS) to put my Lc1 in the stock location definitely tight...The drivers header O2 is easy though.
