Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
spark plugs
Old Apr 10, 2006 | 09:27 PM
c5_ls1_6spd's Avatar
Default spark plugs
i have tr55s gapped at .050, will i notice any difference if i gapped them down between .040-.045?
Old Apr 11, 2006 | 06:00 PM
molson's Avatar
I think those come pre-gapped and could be damaged if you try to adjust them...If they are the iridiums
Old Apr 12, 2006 | 06:00 AM
Patman's Avatar
If you're going to run the gap that low, you should go with the TR5s. They are the same heat range but come from the factory at a gap of .039, while the TR55s come at .059. NGK recommends only adjusting the preset gap by plus or minus ten thou, so you'd be out of their recommended range if you gapped the TR55 that low. Besides, you don't need to go lower than .050 unless you're running nitrous or forced induction. It won't hurt anything to go that low, it's just uneccessary that's all.
Old Apr 14, 2006 | 09:27 AM
MICAH HERRON's Avatar
From: Johnsonville, SC; but orginally from GAINESVILLE, FL
Do not adjust iridiums' pre-gap, they are gapped to the correct spec and could cause problems if you try and alter them.
