NA or FI route
which route should i take?
Second option is the A&A Vortec package..$5500 including fuel pump, good for 550-575RWHP with headers and small cam...Fiqure $1500-1800 installed and tuned. Or do the install yourself. Not that hard. I did it myself...You don't need the LS6 heads to make good power with forced induction...I am about to build a fordged 346 bottom end for mine. The parts came out to about $2200 including a new block so I can still drive my car while I build the motor. Doing all the labor myself..Going to hit 750-800rwhp with that and 15psi of boost...
Second option is the A&A Vortec package..$5500 including fuel pump, good for 550-575RWHP with headers and small cam...Fiqure $1500-1800 installed and tuned. Or do the install yourself. Not that hard. I did it myself...You don't need the LS6 heads to make good power with forced induction...i would go the blower route but my cobra has a blower on it and for the vette i'd like to try something different and go the turbo route.
well i just thought of another option that is alot cheaper than the 427 and STS kit. Cartek 4x heads/cam, Fast 90/90, injectors, EWP, aggressive tune for a possible 510rwhp.
who else besides STS makes turbo kits for our cars?
150 for a tune... thats cheap
if you go FI I would plan on a forged bottom end sooner or later.
It really just depends on what your goals are for the car.
I get what you're saying, but do you really need much more power under 3K RPM? My Z is pretty much stock, and I have a difficult time keeping it from spinning under 3000 RPM's as it is! I can only imagine how much rubber I'd be wasting if I had that much more down low...For me, the STS kit is a great kit; not as efficient as a Front Mounted, but if you're looking to put down great numbers, keep the engine bay cooler, and have the ability to completely remove the entire kit quickly, and without a trace of it ever being there, and have 500+rwhp on even the base kit, then the STS kit sounds pretty convincing. TRTurbo can do the whole thing; intsall, upgraded injectors, tune etc... for under 10K
Thats the route I'd be going if I had that much coin to "play" with. Just my $.02
