Is this oil pressure normal for a vette?
Thanks guys
Thanks guys
I see as low as 29psi after I give the car a good stretch, low comp motor, Mobil 1 10W30, at 220 degrees.
Some guys see as low as 8psi at hot idle!!!!! Now THATS a little scary to me.
8lbs at hot...OIL IS TOOOOO THIN!!!! (imo)
, just hooked up my autometer oilpressure gauge for the first time and started the LS1 in my 67 Camaro, mine is steady at 30 psi to
. Thought it was supposed to be 50 psi at idle Mine has an idle oil pressure of 28-29 psi when the oil temperature is 200F. Mine is auto, but the idle has been raised by 100rpm via LS1 edit.
I'm running German Castrol 0w30, which is almost a 0w40.
