Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Magnacharger C6 Vette Results!
Old Apr 20, 2006 | 08:58 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Thumbs up Magnacharger C6 Vette Results!
Wow, what a week of thrashing trying to get this Corvette ready to attend the Year One show this weekend. Thanks goes out to Mike at Icon Autosports for assisting with the cam, exhaust, and blower installation. We worked to almost midnight twice this week. Conley's Performance Plus stayed open until 1am this morning dyno tuning the car on their Mustang chassis dyno. But, I'm happy to say the car is DONE....for now
Specs:
2005 Corvette Z51, 6-spd manual
230/230 .591/.591 114 CompCam, valvesprings, pushrods
LG Motorsports longtube headers with X-pipe (no cats)
Magnaflow catback system
Magna Charger supercharger with 42# injectors, low boost pulley.
stock shortblock, stock unported heads, stock fuel pump with Magnavolt booster.
The big pulley on this blower made a whopping 5.0 psi boost. Sounds somewhat low, but its safe I suppose. This one has a 3.4" pulley on it right now, I had a 2.90" pulley on my previous Magnacharger car.
Mustang Chassis Dyno, tuned with wideband O2 and HP Tuners:
509.88 rwhp, 456.56 ft-lbs
This Mustang Dyno is about 8-10% lower in numbers compared to the typical Dynojet brand dyno numbers. For comparison's sake, that means between 550-560 rwhp via Dynojet.
Not bad for only 5 psi and a safe A/F tune!
The torque line is amazing on this setup. At only 3K rpm, it hits over 400 ft-lbs (432-440 Dynojet) and goes nearly straight across the entire powerband.
Needless to say, this car feels completely different than before. I did some ~ahem~ test runs at 2am on a deserted backroad at 140 mph and it was scary fast. Raceweight is around 3385 with me in it.
I'll have some nice pics over the weekend, if anyone is going to the Year One show at Road Atlanta this weekend, stop by and check it out.
Tony
Old Apr 20, 2006 | 09:03 AM
V-seriesTech's Avatar
not bad numbers at all nine.
I'm sure the car is fun as hell to drive.
Old Apr 20, 2006 | 10:23 AM
Bad Habit Bird's Avatar
Isn't that about as much air as that blower can push?
I bet is is fun to drive
Old Apr 20, 2006 | 11:04 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Magnachargers can push 12 psi with the right combo of pulleys. My '69 pushed 9.5 psi with just the front pulley changed out.
Dyno sheet attached, showing RPM range between 2900 to 7000 rpm.
Old Apr 20, 2006 | 11:12 AM
Tiago's Avatar
Nice Graph
Old Apr 20, 2006 | 04:05 PM
Goonie's Avatar
damn sweet numbers and a sweeter ride!
Can i have your baby?
Old Apr 20, 2006 | 04:07 PM
SilverSSGabe's Avatar
Sounds like a great setup!
Old Apr 20, 2006 | 05:10 PM
ProjecT 9's Avatar
awesome man, ill be at the YearOne event so ill swing by and check it out...
Jon
Old Apr 21, 2006 | 08:39 AM
So how much rwhp is it capable of making? I thought they were only good to about 550rwhp.
How is the drivability?
Old Apr 21, 2006 | 09:24 AM
Driveability on a magnacharged vehicle will be just about as close to factory as possible. With the cam he has, which is pretty big for a blower,....I would imagine would still, be very driveable,....very.
Old Apr 25, 2006 | 02:30 PM
Nine Ball's Avatar
LS1Tech Co-Founder
230/230 isn't a big cam for a 6.0L engine. It has excellent drivability and sounds nice. The loping black Corvette attracted many inquiring minds at the car show this weekend. Here are some pics:
Those are the factory fuel rail covers. Conley's in Houston cut them and notched them to fit the blower setup perfectly, they did my dyno tuning.
Tony
Old Apr 25, 2006 | 02:44 PM
algws6's Avatar
hey tony, when you get tired of this toy let me know.
Old Apr 25, 2006 | 10:01 PM
~JOSHUA's Avatar
That's a fine machine.
Old Apr 25, 2006 | 10:09 PM
unit213's Avatar
Administrator
That blower looks like it came from GM that way. What a beautiful fit.
Old Apr 25, 2006 | 10:49 PM
marcus769's Avatar
Nice, very nice!! Do you plan to put a different pully on there or leaving it as is for time being?
Old Apr 25, 2006 | 10:55 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Its fast enough for now. More HP just means I'd have to beef up the weak rearend and replace the clutch. 550 rwhp is awesome in such a small and lightweight car.
Old Apr 26, 2006 | 07:43 AM
SPANKY LS1's Avatar
Tony- Is it your opinion and that of Conley's/Icon that the motor can handle that amount of power for a fairly long period of time without issue?
How does it feel SOTP-wise, in comparison to your '69 and the blue car with the big motor in it, and compared to other cars you've driven?
Does the blower "whine" alot, how noisy is it?
What kinda numbers do you thing you would have seen without the cam?
Shawn
Old Apr 26, 2006 | 12:00 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Icon/Conley's haven't had much LS2 boost experience, so there really isn't much historical info to make calls like that. All we know is that the car is tuned on the slightly rich side, and is only making 5psi boost. It "should" live pretty well under those conditions. It also had 0 knock retard during the tuning sessions, even with a blazing hot blower.
SOTP-wise, it feels much quicker than any car I've owned so far. Mostly because it is so lightweight. Its about 200 lbs lighter than the Formula and the 69 Camaro. Those cars would have needed 700 rwhp to hang with this one from a roll.
Blower is ultra quiet until about 6K rpm. It screams up to 7K rpm and sounds wicked.
On a stock C6, the Magna is worth about 120 rwhp (estimated). If they pull 350-355 rwhp stock, they should make around 470-475 rwhp with a Magna at low psi.
Tony
Old Apr 26, 2006 | 01:30 PM
Tony
This statement actually made me recognize how fast the car must be
With the cost of the blower and headers / exhaust do you think a turbo setup would have been better or worse for a daily driven car as far as power and reliability?
Old Apr 26, 2006 | 08:46 PM
pdd's Avatar
pdd
beautiful job and car
