What should a 01 C5 Coupe 6 speed with 480rwhp/420 tq, 305 Drs, headers, run in 1/4?
Mines 500rwhp 348.....NA* And If it dont go 10's On motor, I will burn that car to the ground!!
Ps: With 489rwhp that car should go into the mid 10's on motor... But, You got to drive the damn thing and launch the car with a 1.45-1.55 60ft any less your babying the car.... Just goto to car show
Originally Posted by marcus769
I'm about to buy such a car, and was just curious what I should expect to run in the 1/4 mile with 305 Drag radials, 4.10 gears, LT headers, 3" X pipe, and borla straights? (moderate driver w/ 6 speed). I'm waiting for some paper work, and the car should be shipped next week! I'm fired up! Car was built/dyno tuned by Futral Motorsports.
Thanks guys! Im getting excited!
Those pesky crotch rockets will suprise you unless they are just a 600cc one.
Also you have to realize your DA and where you are at. Like I said our air is ussually 4k to 7k' and our cars run slow compaired to Houston where we ussually run about .7 to a full sec. faster.
Much better tires are:
mt et street radials
M&H drag radials
et streets and skinnies.
These tire will allow you to launch much higher and not spin as much on the 1-2. Then, your chances of running tens will be much greater. If your fairly new then set your starting goal at 11.5 and work your way down from there.
Those nittos are good for a mid-high 1.5x but they won't be consistent and it will take alot of practice to achieve that on a well prepped track. You will have to learn how to slip the clutch and squeeze the throttle precisely to get the best 60' time. With all that hp the et streets will be much more consistent and less technique sensitive.
On a well prepped track in good air with traction, a mid 10 is possible but difficult.
My car had 475rwhp 409rwtq when I ran 10.5@130.5.
