Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
ls7 clutch
Old May 31, 2006 | 11:57 PM
c5_ls1_6spd's Avatar
Default ls7 clutch
would an ls7 clutch fit on my '02 C5?
Old Jun 1, 2006 | 12:37 AM
DarkC5's Avatar
Yes it would. I have a LS7 clutch with a LS2 clutch in my 00 C5.
Old Jun 1, 2006 | 05:42 AM
Ranger's Avatar
King of the radial tires
I have an LS7 clutch on my C6Z. And I don't recommend it to anyone.
It is heat intolerant, hanging the clutch pedal on a pristine launch >3800 rpm.
My C5Z LS6 clutch would handle 4600-5200 launch without complaint and not make the fragrant eau de clutch.
The LS7 pedal will hang and stink.
Now if you do no launches, then the LS7 clutch may be OK. If you do launch, stay away from the LS7 clutch.
Just a thought.
Ranger
Old Jun 1, 2006 | 06:16 AM
PA Z06's Avatar
Just a thought.
Ranger
Thanks Ranger
I was thinking about what clutch I wanted, I know it wont be a spec, or ls7
Old Jun 1, 2006 | 06:43 AM
Ranger's Avatar
Originally Posted by PA Z06
Thanks Ranger
My 02 Z06 was 363 rwhp with just a CAI.
The LS6 clutch worked well and gave about 150-175 drag strip launches per clutch with launch rpm ranging from 3600-5200. Only about 20 of the launches were at 5200.
If you increase your rwhp or plan a lot of passes, I'd look at a Cartek clutch. Hundreds of them are taking tough love well at the drag strip without much issue.
If you go to a clutch with clamping power beyond stock, then you want to consider hardening the rear too while the drive train is apart for the clutch install.
Ranger
Old Jun 1, 2006 | 07:29 AM
~JOSHUA's Avatar
Ranger - What you said matches an article I read last night perfectly. (and my personal experience with the LS6 clutch 421 rwhp)
I was just reading a drag test in the new GMHighTech mag on the new Zo6 and they said after the 2nd hot lap the clutch was done. They couldn't get more than 2 or 3 runs before parking it for an hour. And still they said it was no good even on the good passes.
My factory LS6 clutch has been flat out abused on the track and tons of mountain racing at 421 rwhp and it has been perfect for around 40k miles. It just gave me the 1st sign of it's mortallity last weekend.
I was thinking about getting an aluminum LS2 flywheel and the LS7 clutch, but after reading the magazine article and hearing what you said I don't think I'm going to go that route.
Screw SPEC also, I don't want to be in a wheelchair after the pressure plate explodes @ 5k rpm.
Old Jun 1, 2006 | 08:59 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Larry @ Speed Inc. is running an LS7 clutch in his 02 Z06, I think he's cut a few 1.6's.
Old Jun 1, 2006 | 09:18 AM
~JOSHUA's Avatar
Anyone else here have some milage on an LS7 clutch?
Old Jun 1, 2006 | 05:53 PM
Ranger's Avatar
I cut way over 100 1.6X 60' on a stock LS6 clutch on DRs. If the clutch fluid is properly maintained, the LS6 clutch gives an excellent service life, very common to get 100-200 passes from one.
The LS7 clutch on the C6Z pales in comparison. I have not met a single C6Z06 owner who makes passes in his car that has anything but complaints about the clutch. It hangs the pedal on a pristine launch >3800 for goodness sake.
Juxtapose that with my club's last drag day when about 15 C5 Z06s with stock LS6 clutches were making passes on drag radials, many at launch rpms of 4000-5000 and not one had clutch issues.
I do not recommend the LS7 clutch to anyone that plans to make passes.
Ranger
Old Jun 2, 2006 | 05:27 AM
PA Z06's Avatar
Ranger
Thanks for the sound advice Ranger
Old Jun 2, 2006 | 09:03 AM
SteveDoten@ARH's Avatar
Closed ex-Sponsor Account
I used a LS7 clutch/fw recently w/ a new LS6 slave and McCleod master, maybe the master on the new Z is the weak link?
Old Jun 2, 2006 | 09:21 AM
Ranger's Avatar
Just curious. Did you use the LS7 clutch on the drag strip?
If so how many passes and at what general launch rpm?
How did the clutch behave at the drags?
Ranger
