Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Please help!!!!
Old Jun 6, 2006 | 06:50 AM
charlie c5's Avatar
Default Please help!!!!
I'm in the middle of doing a cam swap on my automatic 00' C5. Anybody have any tips on getting the crank pulley bolt loose.?
Old Jun 6, 2006 | 06:58 AM
V-seriesTech's Avatar
I think it's a 24mm bolt. We usually use air...come right off.
If it was manual, and I was doing it by hand, I'd say put iti in gear...and try breaking it loose.
Are you trying to just get the nut off?...or did you get the nut off and now trying to get off the pulley?
If its option 2....you need a pulley remover for that.
Let me know.
Old Jun 6, 2006 | 09:14 AM
SteveDoten@ARH's Avatar
Closed ex-Sponsor Account
Ingersoll Rand 2135Ti impact gun
Old Jun 6, 2006 | 12:32 PM
charlie c5's Avatar
Let me know.
I have a pulley puller, I'm trying to get the bolt off.
Old Jun 6, 2006 | 12:55 PM
Oneeye's Avatar
This will work.http://store.summitracing.com/egnsea...N=115&x=36&y=9
Old Jun 6, 2006 | 01:06 PM
charlie c5]I have a pulley puller, I'm trying to get the bolt off.[/QUOTE]
Ok then. SInce I am guessing your not useing air?..
Go underneath a WELL JACKED AND BALANCED VEHICLE... please support the car properly.
Then, on the bellhousing, they're should be some sort of a hole/or that you can see the flexplate/flywheel.
You can use a big screw driver...or even a prybar...depending on ground clearence. You'd need two people. One hold the flywheel from turning, while the other removes the bolt.
Should work.
Old Jun 6, 2006 | 08:46 PM
Steve01SS's Avatar
Never done it on an automatic without air tools. On an M6 you can, put it in gear and stomp the brakes and hold the parking brake. You can use a long breaker bar.
AIR TOOLS are the way to go though... never gonna try again without em..
Old Jun 6, 2006 | 09:25 PM
99FRC's Avatar
I took the handle off of my floor jack and used it as a breaker bar. I f'in cracked a rib pulling on that thing! Seriously!
Old Jun 7, 2006 | 01:53 PM
charlie c5's Avatar
I am using air, but my air pressure only goes up to 165 lbs. The tool from Summit looks like it may work. Thanks, guys.... LS-1 Tech rocks..
Old Jun 7, 2006 | 02:04 PM
If all else fails....C4 does work.
...but i'd wear protective goggles.
