***New DTE Differential Product*** (photos)
We are pleased to announce our latest heavy duty Corvette driveline product designed, engineered and produced by Dynotech Engineering Inc., specifically targeted for the 1997-2004 Getrag differential found in the M6/M12/A4 C5 Corvettes' using any gear ratio or any 2/3-series differentials. We've been developing this product for a few months now and have settled into this final design that is scheduled for full production.
Why this product was developed?
The current O.E.M. Getrag differential configuration uses the right side removable cover of the unit to provide the carrier bearing outer race saddle that supports the right side of the carrier, which carries the ring gear. This side cover must provide bearing support, differential sealing, resist deflection and to provide enough structural support to resist the natural tendency of the carrier assembly from trying to "walk" out of the case under heavy stress loading as a result of hard acceleration.
That O.E.M. design is quite strong and even stronger in our aftermarket preparation~ but the current right side cover still has its deficiencies, mainly due to it simply being a "cast" piece of aluminum that often times contains metallurgical porosity, voids and casting flaws within it that can't be seen, which inherently produces a weaker casting from these flaws. We've literally scrapped hundreds of the O.E.M. castings that don't meet our high quality standards just because of this trait alone.
When the O.E.M. casting finally does yield to the stress in high performance applications due to metallurgical fatigue, the negative result is split open side covers, heavy cracks, carrier bearing failures and ultimately complete differential failure where nothing is salvageable. This of course is not only aggravating of having your car down, but is quite costly to repair.
Our product is designed to address and correct all of those inherent flaws that are present in the O.E.M. castings...
Improved Design Features
- Our heavy duty right-side cover is manufactured entirely of aircraft industry grade 6061-T6 billet aluminum using CNC processes for absolute repeatable dimensional accuracy from piece-to-piece.
- Heavy circumference "girdling" of the entire part for added mounting ear strength.
- Extra thick mounting flanges to resist flange deflection during hard launches.
- Improved O-ring groove to eliminate side cover leaks.
- Massively thick bearing race saddles to provide superior carrier bearing support that eliminates carrier walk and bearing saddle deflection.
- Improved internal bearing oiling strategies for cooler differential operation and promotes longer bearing life. (This is especially beneficial to road racers)
- Tighter outer seal fitment for improved seal retention.
- Outer seals are physically screwed to the side cover to completely eliminate any chances that the outer seal can pop out of the cover. (This is also especially beneficial to road racers)
- Removable lubricant deflector that cannot break off like the O.E. parts do.
- Deep bearing race saddle pockets that allow for more accurate carrier shimming for high performance use.
- Improved oil deflector design that funnels larger quantities of lubricant to the bearing faster, while shedding any unnecessary lubricant sooner to prevent bearing oiling starvation under high cornering loads, while simultaneously eliminating seal "flooding" from too much oil feed.
- Heavily radiused corners to eliminate cracking.
- Extra thick main body to eliminate side cover deflection as a whole and to provide the main case additional structural rigidity.
- DTE name and website engraved into side cover for easy identification
This product can be ordered as an option for any one of our differentials we build here or can be purchased outright for the DIY'er and/or for your tuner-builder to install. It will be sold as a kit that will contain a new outer O-ring, outer axle shaft seal, axle shaft seal retention stainless steel fasteners, oil deflector and deflector retention stainless steel fasteners.
This product will fit with any model of differential strut we have ever produced and is *STRONGLY* suggested for anyone who is *serious*, that takes their car drag racing, road racing, DE events or auto-x. We suggest that this product be installed by individuals or companies familiar with the Corvette Getrag differential.
Production of this product will commence next week and the kits should be available approx. 2 weeks after that. Pricing will follw shortly, but the complete kit should fall into the $699-$749 range.
Finally, this product has been in development for quite some time now and it's just another one of our HD Corvette driveline products exclusively designed, engineered and produced by DTE to meet the high driveline durability needs of the Corvette IRS differential owner, both now and in the future. We've got a few other related components in prototype now that will be released within weeks also and we'll never cease in trying to engineer the "perfect part" to meet everyone's needs!
*Photos display the kit contents, and stock vs. our product for both front and backside views.
We're serious about Corvette IRS driveline durability. Are you...???
If anyone has any questions, please don't hesitate to call. (260)407-5455
Best Regards,
DTE
Best Regards,
DTE
Regards,
DTE
Best Regards,
DTE
Last edited by 2002_Z28_Six_Speed; Jul 28, 2006 at 02:00 PM. Reason: He altered his post to discredit me.
Does all of that make you feel better now?? Nice try, but put down the physics book and step away from the keyboard... You and most others who do not or can not understand what vector loads we're targeting typically miss the entire design concept of what we've already successfully proven with our products design.
Aren't you late for your Yank support group meeting?
The one irrefutable fact about arguing with a fool is that they will drag you down to their level and then beat you there with experience...
Your predictable fishing for an internet argument will yield no bites here. As far as the rest of your silly comments~ thanks for the comic releif.
Good day.
Explaining why you did what you did makes me look bad. Sorry I was interested.
Last edited by 2002_Z28_Six_Speed; Jul 28, 2006 at 02:01 PM. Reason: He altered his post to make me look bad for asking questions.
Those are three very good customers of ours that use our dyno for testing and their looking over the 1007 N/A RWHP they had just made with their car that has a 704 ci Donovan big block/Lenco combination in a 1993 Chevy Lumina tube chassis car. They were quite pleased, so the photo was taken of them for their scrap book and these "redneck dummies", as you so comically put it, have consistantly put that car into the high 6's week after week.
Thanks for taking the time to look at our website!
You must be a young, immature whipper-snapper to be such a fiesty keyboard commando like you are, which makes you quite predictable and the other "redneck" office personnel
Best Regards,
DTE
Also, please rationalize why your Differential Strut kit places the struts in a manner where most of the force causes the ASM to compress and expand until the rod ends reach tension and not resist the moment caused by the torque of the engine. Placing the strut rods to where they have a smaller angle between them and the moment caused by the engine would reduce the amount the trans and diff could rotate relative to one another. Also, why rod ends with ball joints in them? That allows more movement before the struts can resist movement.
Also please tell me why you chose strut rods as they are best used in a structure to distribute tensile loads.
Plus, the fact that strut rods deflect due to the nature of how they are built means that your kit actually allows the trans and diff to rotate to a certain point placing cyclic loading on the fasteners.
All in all the kit is a bandaid and if the diff wasn't strong enough to hold the load (not considering cyclic) before the strut rods came into effect the diff would still break.
One final thing: Since you are an Engineering firm can you supply the name of one person who has passed the PE exam at your firm? Because it is technically illegal to call yourself an Engineer who produces items used by the public without it.
BTW, I also have a degree in Mechanical Engineering, with 10 years industry experience. The only thing I could think of when I read your reply is that you are using this in a condescending manner. Just by reading your comments, you come off as a keyboard warrior armed with a physics book. Your only goal here is to start trouble, and I'll go ahead and give you this ONE warning: Do not reply again in attempt to harass DTE, or your user account will be locked down for a period of time.
Tony
