First pic - APS C5 twin turbo system
#61
Peter I agree that it's possible, I wasn't arguing that point at all. I did mine in a one car apartment garage on jackstands, but it sure was easy.
Personally, I had to lower the k-member, raise the engine away from the subframe at the same time, and remove the engine mount pedestal on each side to shoehorn each assembly in place.
It's possible as you mentioned, but you really need to have some serious skills going into the project or it's not gonna happen.
That Corvette kit looks like a gem, I just wanted to urge prospective buyers to pay the money to have it installed. Well worth the frustration saved.
joegrunt- Thanks for the kind words! I stand for quality, call me if you have any questions. ~Joshua
#62
It's possible as you mentioned, but you really need to have some serious skills going into the project or it's not gonna happen. That Corvette kit looks like a gem, I just wanted to urge prospective buyers to pay the money to have it installed. Well worth the frustration saved.
Peter
#64
Originally Posted by Exotic Performance Plus
I would welcome the chance to install an APS turbo system. Bob
#65
#66
Originally Posted by peter@aps
Bob, I'd say given your profile there's a better than even chance that you will instal many C5 twin turbo systems over the coming years.
#67
Originally Posted by joegrunt
Thanks Peter, guess I need to find a shop! lol Just so my slow brain takes all this in, if I put this on my C5 I need to put in new pistons and a new cam also?
I was wondering what the answer to JoeGrunt's question is? Looks like an awsome system. How much do you think a reasonable install would be?
Thanks,
Rusty
#69
Originally Posted by Rusty,s C5
Peter,
Thanks,
Rusty
Thanks,
Rusty
#70
Rusty, I did a web search and found a kit for a C6 that listed for 9k, you will have to ask the guys here who do installs how much we can plan on spending for it. I also need to know if I need to do a piston and cam upgrade as well. Plus I have been thinking, will we need to upgrade our stock brakes for this increase in hp?
Thanks for the info. Yeah I would like to know the answer to all of those questions. Your probably right about the brakes, I didn't even think about that. Thanks for that tip also.
#72
Do you plan on putting out a list of everything that you need to do in addition to the install?
Peter
#73
Joegrunt, The APS twin intercooled twin turbo system is designed to run on a bone stock LS1 engine (a set of stronger valve springs would be ideal to eliminate valve float and a set of colder plugs may be required) and will produce around 550-575 rwhp with a thorough dyno tune on 93 octane fuel. There's no need to go with forged pistons or rods, bigger cam/heads (between 500 to 600 whp) unless you're wanting to push for mega HP in the future, hope that helps and let me know if you have any other questions, happy to help out.
Peter
Peter
Thanks Peter.
#74
Will I need to upgrade my stock brakes? At 575 rwhp, it would seem that the stock ones wouldn't cut it.
I would think you would need a new cam, but then again I have never even thought about this type of set up on a car.
Thanks Peter.
Thanks Peter.
Peter
#75
Nope Peter, 575 will do me just fine. I have stock exhaust, do you recommend upgrading it? And I will take your advice on keeping the cam in there the same. As you can see I have a lot to learn about this application!
#76
peter
#77
I
The C5 twin turbo system has a true dual 3'' exhaust system included (not the rear muffler, see pic below) which bolts up to the stock C5 rear muffler assembly. You can choose to retain the stock muffler or replace the rear muffler with a high flow aftermarket muffler, this really depends on your power goals and also if you want to keep the exhaust note fairly quiet (and avoid drama with the law), your choice either way.
peter
peter
#78
It looks great, but I would like a little more sound from the back. Nothing too loud, but something that would make it stand out a little I believe. Thanks for all the help on this Peter, it is appriciated!
Peter
#80
Originally Posted by Cheatin' Chad
This kit as well as all of the others I have seen from your company is simply beautiful.
Great work!
Great work!
Peter
