Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
car keeps going into low power mode-help
Old Aug 20, 2006 | 06:18 PM
pdd's Avatar
pdd
Default car keeps going into low power mode-help
http://forums.corvetteforum.com/show....php?t=1473015
Old Aug 22, 2006 | 12:00 PM
sonicbaloo's Avatar
Did you get your answer on the other forum?
Chad
Old Aug 22, 2006 | 12:51 PM
minytrker's Avatar
Did it start this after the cam install? When does it going into reduced power mode? It sounds like the etc predicted airflow is high enough in the computer. I had this happen to me after I put my cam in. Its table {C6101} in efi live.
Old Aug 22, 2006 | 03:00 PM
pdd's Avatar
pdd
Chad
no. i took the car out today and it died for no ****** reason 3 times. i have to sit on the side of the road for a few minutes with the car off, then it starts. i had a few people tell me to check the TPS , which i did, but im gonna go over it again with a fine tooth comb. also someone said that air might be getting past the MAF unmetered, but how the hell is that possible?
Old Aug 22, 2006 | 03:03 PM
pdd's Avatar
pdd
it goes into reduced power mode at any time, goofin off or just cruizin around. it was happening before this cam i have now, but not as much
Old Aug 23, 2006 | 09:21 AM
linn.35's Avatar
Try to see if the throttle blade opens when the ignition is on but the motor not running. If it doesnt open it is something with the TPS or the throttle blade motor. Had the same issue and it ended up being a bad TPS. Did it all the time. My throttle blade wasnt opening at all. See what does and get back to us.
Old Aug 23, 2006 | 02:31 PM
pdd's Avatar
pdd
throttle blade opens all the way when floored
Old Aug 24, 2006 | 01:30 AM
linn.35's Avatar
Try to find another TPS sensor to switch with and see if that works. Even though the blade is opening, the sensor might not be detecting where it is at. Try that and get back to us. Also maybe have your tuner try turning off the codes completely and see what the car does. If you think it is unmetered air, have the tuner turn the car to Speed density mode and see what happens.
Old Aug 24, 2006 | 01:10 PM
pdd's Avatar
pdd
ok ill order one. also as a side note, when i pulled the air bride to check the TB blade, all looked good. so i put the air bridge back together. took the car out for muliple rides, spirited driving and cruising, the car didnt break down once. so im gonna keep my fingers crossed that something was loose on the air bridge, but i doubt it will be that easy of a fix with my **** luck
Old Aug 24, 2006 | 09:39 PM
linn.35's Avatar
Also make sure you got a good ground on your battery terminal. My car was runnin great and I disconnected the neg on the battery for 5 mins to hook up some nitrous stuff, hooked the neg back up and car kept goin into reduced engine power mode. I had to keep moving the ground on the battery till it got a good connection. I also cleaned the terminal as well to help. Once it got good contact, I tightened the hell out of the bolt.
