Tired Of Oil In Your Intake?
Oil enters the intake through your PCV valve, being drawn in by vacuum. This oil acummulates and pools in the intake. The oil will make its way down into the intake ports, around the valves and will drip into the combustion chamber to be burnt, as it mixes with the fuel. Some of the tell tale signs you have this problem is an oil and carbon residue on the rear of the car, smoke during hard acceleration and the most obvious, oil on the back of the butterfly valve on the throttlebody. The catch can is put inline before the PCV valve to trap the oil before it reaches the PCV valve. Here is a link to the oil catch can I purchased. http://store.zerotek.net/unjdmalraoil.html
PS i have a blue one in mint condition complete with instructions if anyone is interested?? $140
here is the site http://www.accmachtech.com/pcvcatchcans.htm
www.ipsmotorsports.net
It was about 60$ if I remember correctly. This solved my oil in the intake problems as well and alittle smoke on start up was fixed too.
NEED2SPEEDLS1 it is not just a C5 Z06 thing or even a C5 thing - almost every LS1 can benefit from this. My '00 would smoke bad on the dyno, it was consuming that small bit of oil that was being pulled through the intake. Not only that - but if you are consuming oil, you are leaning out the a/f ratio so you might not be able to run as much timing as you like. Put a catch can on and you'll find about a teaspoon of oil...
Ryan
Highly recommend mod. I was trying to buy the AMW one but, it's backorder until november. Very nicely built pieces, we put one on a cadillac recently.
It's important to know how to have your PCV system hooked up properly...make sure you hook it up right.
That is the exact same one I have on my car, but black. I'll try to get some pictures of it installed & post them.
intake is dry as a bone
