Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
help plz...abs and sys came up
Old Aug 26, 2006 | 11:04 PM
SVT BAIT's Avatar
Default help plz...abs and sys came up
I was on the freeway driving and then on my dash board ABS lightt came on and it said service abs and traction sys code aswell what can it be am I really fucked? Sensor I hope?
Old Aug 26, 2006 | 11:16 PM
SVT BAIT's Avatar
By the way its a 97 C5 thanks
Old Aug 27, 2006 | 08:43 AM
GTFORMULA's Avatar
Could be a wheel sensor.
Old Aug 27, 2006 | 03:22 PM
DarkC5's Avatar
Is the code/light staying on? Ususally if you turn your car off then start it the code will go away. Pretty common with vettes. You could've hit a bump in the road will braking/accelerating and the sensor picked up on it. I wouldn't worry too much.
Old Aug 27, 2006 | 06:13 PM
SVT BAIT's Avatar
Yea when I turn the car off and turn back on its not there it comes back after like 10 mins of driving...but I hate driving with codes on my dash/...so what do I have 2 replace so it won't come back at all?
Old Aug 27, 2006 | 07:16 PM
RPO_Z06's Avatar
Pull the codes on the DIC and see what it is.
Old Aug 27, 2006 | 07:26 PM
DoesSpeedTurnUon's Avatar
search "EBCM" on CF. It's a sensor.. well more like a computer, my 2002 does it. TONS of C5's have the same problem yet GM won't recall it.
It's about a $600 computer.
Old Aug 27, 2006 | 07:43 PM
jargan04's Avatar
If you pull the codes and get C1214 get ready for a *** rapeing. 90% of the time the ebcm is dead.
Old Aug 27, 2006 | 07:47 PM
I haven't got a 1214 but mine gets "service active handling" or "service vehicle soon" or I'll feel my front brakes slow the car down (it will dip) when my feet aren't on the pedals, and i'll look at the DIC and it will say "Active Handling"
Old Aug 27, 2006 | 08:19 PM
SVT BAIT's Avatar
**** 600? So if the computer is fried that's what's causing it? I really hope is sumthing stupid like a sensor or something! What do I push to check my codes? Sorry just got the vette I don't know how
Old Aug 27, 2006 | 09:05 PM
turn the key to the on position but dont start it.
push the "Reset" button to clear any codes that may pop up on the DIC.
Then while pushing "option" push "fuel" 4 times.
It will go into the diagnosis mode.
I get confused on what the other buttons do while in that mode, but if you push E/M it will exit, and obviously, the reset button will clear any codes you may have.
Others here may have more knowledge to this subject.
Old Aug 27, 2006 | 09:54 PM
SVT BAIT's Avatar
Oh ok thanks ill try in a bit....so there's a chance ill be wastin 600 dollars on this problem?
Old Aug 27, 2006 | 10:18 PM
SVT BAIT's Avatar
Ok I just did that I got no codes for C1214..but there was a few others
Old Aug 28, 2006 | 10:31 AM
jargan04's Avatar
Then it's not the EBCM. I hate to replace mine a few months ago.
Here is a link to every corvette DIC code and what it means.
http://www.stengel.net/diccodes.htm
Bret
Old Aug 28, 2006 | 11:59 AM
SVT BAIT's Avatar
How much was it? So is it a sensor then?
Old Aug 28, 2006 | 07:36 PM
NEED2SPEEDLS1's Avatar
Bret
well i just pulled a C1214, that was my first code! the car only has just a few codes, and they are all H (in the past) What exactly does this mean now? It cant mean the computer is fried or whatever. lots of people get these codes and they clean up the corrosion built up in the connector. The car is flawless and doing great. Id hate to have to replace something like that after owning it for 3 months from a stupid problem. please send over some more info! lol
Old Aug 29, 2006 | 11:43 AM
jargan04's Avatar
I did all the grounds on mine and it never went away. I had to replace the EBCM on my vette after having it a total of 4-5months. I got very lucky and got a used one off a wrecked repo that was going to auction. Got it for $200.
Old Aug 29, 2006 | 03:42 PM
SVT BAIT's Avatar
200 is cheap I'm hoping itssome harness or sensor I rather spend the 600 for the computer for a perfomance part rather than that but if I gotta do it ill do it...ima get it checked tommorow ima have a few mods done and ill just have him check it out for me I'm crossing my fingers
Old Aug 29, 2006 | 08:38 PM
yea that sounds good. I will be doin the same thing. Im gonna install a intake setup my self and then have it tuned and see what they can come up with. thanks alot for the help JARGAN04. If i have to change the computer out, thats what I got to do. This wont cause any future problems will it? I kinda want some more info to stay on top of this. my service abs light and traction control only come on once in a great while. it only came on twice when i rev'd it real high.
Old Aug 30, 2006 | 11:47 PM
joegrunt's Avatar
I have the same problem on my 01. It will go off for a few days then come back. Also, it will tell me that my LR tire is low, when I check it the pressure is where it us supposed to be. Should I reset the system?
