Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
need help wires going to starter!!!
Old Sep 6, 2006 | 06:58 PM
n2oJOE's Avatar
Default need help wires going to starter!!!
im reinstalling my enigine and i need to know what wires go where on the starter its a 99 c5. please need help asap
Old Sep 6, 2006 | 07:17 PM
mikep2002's Avatar
Mines on Jackstands right now 2002 I will give you colors and wire sizes large/small.
4 wires to my soliniod. Theres 1 purple on top about 12gauge. I have the main battery cable 6/8gauge red and a 10gauge orange wire? There is also a thin black wire on this pole. It is hard for me to look around the headers.
For me purple on top
And Red/orange/black below
Sorry I hate electrical ****(DC)
Old Sep 6, 2006 | 07:27 PM
n2oJOE's Avatar
i have a small black ground i think, 1 red from the battery, 1 orange, and one grayish, and the small purple, its hard for me to see from the top. its weird i just installed my 408 and had it running yesterday did the warm up and breaking and everything was great then i parked it came home tonight and went to crank it and it clicked a couple times then turned over plenty of volts but nothing i pulled one of the spark plugs and put it to a ground and got one spark and that was it so now i have a intermitant starter and no spark i have to guess its a wire installed wrong
Old Sep 6, 2006 | 07:54 PM
mikep2002's Avatar
Let me craw back under and see if I have a grayish. I can only see the 2 posts on the solinoid.
Old Sep 6, 2006 | 08:00 PM
mikep2002's Avatar
Hey joe I can see the middle post from between my plugs and it has what looks like a heavy black ground wire same size as main battery power. That would be the post closet to the center of car/clutch area.
Purple on top
Black Heavy ground middle/closest to clutch
Red/orange/thin wire black all on bottom post
I hope this helps
Old Sep 6, 2006 | 09:34 PM
n2oJOE's Avatar
yes and no all my wires are correct but still intermitant cranking and spark would this be caused if the starter solenoid was bad? im more worried about the lack of spark i know the strater is most likly bad but would that cause the spark problem???
Old Sep 7, 2006 | 12:25 PM
mikep2002's Avatar
I think you need to go into the fuse boxes at this time and check everything out. Good luck Joe I just hate DC ****. I would spend a couple bucks and get a noid light set for the plugs and also get one for the injectors also. It has helped me in the past instead of trying to ground for checking spark. Good Luck
Old Sep 7, 2006 | 06:34 PM
n2oJOE's Avatar
thanks for the help starter problem fixed no gotta figure out the no start
Old Sep 7, 2006 | 08:13 PM
mikep2002's Avatar
Joe I think at this point you should try to PM Kleinete she is a mod over in general maintance and repair she is a tech/mechanic and knows her ****. She has a c-5 and may be able to help you. With no spark I would be leaning torwards a relay. Good luck
