Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
First dyno on the TT ZO6
Old Sep 9, 2006 | 11:49 PM
james02Z's Avatar
Default First dyno on the TT ZO6
Just got my car on the dyno today. It made 621hp and 643tq on pump gas @ 12psi. The car still has the stock cat-back, intake and tb. The tune is a very safe street tune. The car is very quiet and docile until you jump on the throttle.
I cannot say enough about the shop that done the work for me. They had nothing but trouble from the turbo kit from the beginning. The company that made the kit gave us no support at all on anything. They had to do so much fabricating to make things fit that I can not even begin to to list everthing. The car runs cool, everything works and the tune is dead on. I love it!
I have a permanent grin plastered on my face the entire time that I am driving it.
Old Sep 10, 2006 | 02:15 AM
matthewjernigan's Avatar
What kind of turbos are you using. impressive dyno!
Old Sep 10, 2006 | 02:37 AM
HolyShiznit's Avatar
Turbo, set-up, motor, external mods, ECU/PCM??????
Old Sep 10, 2006 | 02:17 PM
james02Z's Avatar
The turbo's are percision 44mm. The boost comes on very quick, especially when the car is under a load. I may go bigger in the future, but right know it is plenty for me.
The motor is a stock cube LS6 with good rods and pistons and a stock crank. TEA LS6 2.5 heads and a small cam -224/232 . Stock intake and tb, 65# injectors, msd bap and Lingenfelter in tank pump. It has a Kook's X-pipe with the stock cat-back.
The tranny is stock with a Aussie clutch. Hardened axle shafts, DTE brace on the way and stock gears are in the rear.
All the tuning was done by Dave Smith at Dave's Total performance using HP Tuners. The car starts and idles perfectly. It drives like stock until the boost comes on,then it will cross 2 lanes of traffic with dr's on. I cannot say enough about their shop. They have done everything on the car from the bottom end to the install of the turbo kit (a complete nightmare) to the tuning. They will always have my business.
I have meth on the car, but I have not used it yet. I also plan to dump some race gas in and crank up the boost eventually.
The only external mods to the car are tinted windows, light covers and black Motorsport wheels (The car is black). I also have a MCM carbonfiber hood on the car. As soon as I get a chance, I will get some pics and post them up. I will also post up some timeslips as soon as I get to the track.
Old Sep 10, 2006 | 02:46 PM
gemballa996t's Avatar
Old Sep 10, 2006 | 04:41 PM
M6HuggerSS's Avatar
wow... sounds like a killer set-up!
can you tell us the location of the shop and the name of the turbo kit.....
also some pics/vids would be awsome!
congrats!
Old Sep 10, 2006 | 05:52 PM
james02Z's Avatar
congrats!
The shop is in Milford, Ohio, just outside of Cinn. I think that their # may be on the dyno sheet.
The kit started out as a PTK kit, but so many things had to be changed so that everything would fit, I would not call it that anymore. Once I get the time, I will compile a list of the problems that I had with it. It should not have even been called a kit. Just a bunch of random parts with no instructions that would not fit!
I have a vid of the dyno and I will get some pics up as soon as I get a chance.
I also plan on making a video of street and track races, donuts burnouts ,etc.
Old Sep 10, 2006 | 10:23 PM
AVB's Avatar
AVB
Sorry to hear the kit didn't fit as expected. Is the dyno sheet misaligned? It's just not crossing at 5200 like I've always seen...
I look forward to some pics, vids and any other info you share
BTW, interested in a Stinger hood?
Arnel
Old Sep 10, 2006 | 11:42 PM
james02Z's Avatar
Arnel
For some reason the hp and torque are scaled differently on each side of the dyno sheet. The hp is on the left and the torque is on the right. I think there is a 50 point difference between the two. I was a little confused when I first looked at it for the first time.
Old Sep 11, 2006 | 12:19 PM
mdhmi's Avatar
Glad you got it back together. You should post this on
http://forums.corvetteforum.com/forumdisplay.php?f=86
as there are a large number of prospective TT purchasers there.
Old Sep 11, 2006 | 02:30 PM
lt1dave's Avatar
Glad your happy with it James! The drive home was rediculous. Can you say smoking tires at 120mph!
Here is the dyno video. (Pulling in 4th with 3.42s). (First pull was only 520, final pull was posted power). Total timing is at 16deg, and 11.5 AFR, with 91 octane pump gas, and stock catback. so there obviously is alot more on the table, but this is the very street SAFE tune.
http://www.youtube.com/watch?v=nDLruefSOZc
Old Sep 11, 2006 | 05:09 PM
2002blackZ's Avatar
James,
Your car is insane! Sounds stock while running but will absolutely eat! I love your hood as well. I wish they made one like it for my Z.
Impressive numbers. Keep it between the lines... if you can!
Keep us posted on the track numbers.
Old Sep 12, 2006 | 11:22 PM
AustinL911's Avatar
Ok, it won't let me view the vid. Says it's a private vid or something along those lines. I've really been looking into this kit, and hearing that it didn't fit right is new to me. I'm hoping they correct any problems before I get one.
Old Sep 13, 2006 | 07:14 AM
lt1dave's Avatar
Try this instead. http://www.youtube.com/watch?v=KYcMv9ZLSX4
As for the kit, Im not big on bashing, so all I can say is you will wish you hadnt bought it if you do. It doesnt fit in any way, not even CLOSE, and there customer service ends with the 4 minute playtime install video overview.
edit: And lets not forget the 8 months (after its paid for) it takes to get the box of parts they called a "kit"
Good luck, but I would advise a different set up
Old Sep 13, 2006 | 02:39 PM
AVB's Avatar
AVB
In defense of the kit, there's more than a few that have been able to install it w/o having to get anything redone. There are those that had to have the manifolds "fixed" and in time they did get the piece they were satisfied with, but you're the first I've heard which didn't get the customer service I always felt they were very good at.
That doesn't take away from the issues you had, just that it's not that way w/ every C5 kit they've sold. Again, I'm glad things are good now and you can enjoy the new power
There are other kits out and some coming out... they seem to all make good power but if you're wanting big power carried to 6500 on big cubes then the choices aren't there unless you want power to come on later (STS). Drop off at 5000 isn't all that great, 5500 is okay and 6500 is great.
Arnel
