Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Help with 04+ C5/C6 fuel systems.
Old Sep 19, 2006 | 09:29 AM
NeverT00fast's Avatar
Originally Posted by algws6
how many miles do you have on your car?
Just hit 13k.
Old Sep 19, 2006 | 09:36 AM
Originally Posted by chriswtx
I havn't heard about this. Last I heard from racetronix was they had a pump that would fit but you had to send your stock bucket to Thunder for them to install it. But the problem of pressure drop in the line still remains the same. The pressure regulator is in the tank. Its trying to maintain 58-60psi in the 9ft of fuel line in front of it. Where as with the regulator in front at the fuel rail, the fuel rail gets the fuel first and the regulator is last in line.
I might just put it in there for shiets and giggles if I'm going into the tank anyway. The labor alone is going to be well over the cost of the Racetronix pump. I'm just trying to decide if I should go in and replace that pump and filter or not. I mean dropping down to 52psi NA is acceptable, but it probably also means that something is wrong with either the pump or the filter. Everybody that I talked to so far said I shouldn't be dropping down to 52psi with a BAP at only 460rwhp NA.
Old Sep 19, 2006 | 07:10 PM
EPP's Avatar
EPP
We normally only see the fuel pressure drop to 54 psi with 8 psi of boost, so it does sound like you have a problem with your stock fuel system. Bob
Old Sep 19, 2006 | 08:37 PM
And this is on the newer fuel system with a KB BAP connected?
Old Sep 20, 2006 | 04:48 AM
EPP's Avatar
EPP
Smile
Yes. Bob
