Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Replacing Driver Side Headlamp
Old Oct 15, 2006 | 11:46 AM
1fastTransAm's Avatar
From: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
Default Replacing Driver Side Headlamp
Anyone Have Instructions On Doing This Job?
Old Oct 15, 2006 | 12:50 PM
Sigforty's Avatar
What are trying to replace it for? I do not know if there are instructions anywhere, but I can give you a good idea of what needs to be done.
First you can start off by using the manual crank on the headlight to raise it up. Then remove the 3 screws on the plastic cover that goes around the sides of the head light. Once that is off you can work your hand down into the headlight bezel. There are 3 10mm nuts that attach the back of the headlight to the fender. Finally you have 3 13mm bolts that attach the headlight to the frame right by the radiator. After that just carefully work the headlight out so as to not damage any paint on the car.
