Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
clutch issue
Old Oct 27, 2006 | 08:29 PM
W8N2SQZ's Avatar
Default clutch issue
Okay, this might be in the wrong forum, but my buddy just bought a used 03 Z05 with 18k miles and the clutch pedal sticks to the floor.
I have a 6 speed camaro and it used to do this and I bought an aftermarket clutch and master. Will my friend have to do this as well?
Can any of you Z06 guys shed a little light on the subject?
I will post this in the trans section as well
Thanks,
Glenn
Old Oct 27, 2006 | 08:36 PM
blk04z's Avatar
I had the same issue. I replaced the clutch,flywheel, and slave. Keep the clutch fluid clean
Old Oct 28, 2006 | 11:46 PM
W8N2SQZ's Avatar
Thats what I thought.
Thanks for the advice.
Glenn
Old Nov 12, 2006 | 09:52 AM
1stz06's Avatar
There are 2 simple cures for this and one that is not so simple, mentioned above......new clutch, slave, flywheel!! Change to dot 4 clutch/brake fluid and keep it fresh. Change it out of the reservior everytime you add gas. Also, there is a clutch stop you can buy for around $100 that keeps your clutch pedal from hitting the floor which allows quicker shifts and greatly reduces the sticking clutch pedal syndrom. Do a search on the corvetteforum. There is a guy that just did a write up about it. Very impressive!!!
J.R.
Old Nov 12, 2006 | 11:51 AM
V-seriesTech's Avatar
Look up the name RANGER... he's a member. Dude has great reviews for do it yourselfers as well.
Old Nov 12, 2006 | 08:54 PM
Steve01SS's Avatar
Yeah, the stock GM clutch blows.... GO with an aftermarket clutch and the sticky pedal problem will be solved... Everyone I know has had this problem. Replaced the clutch and it goes away...
Your camaro had the same clutch...
Steve
Old Nov 12, 2006 | 09:00 PM
NEED2SPEEDLS1's Avatar
yea Ranger def knows his stuff. Great guy. iv read alot about peoples cluth stickin to the floor. worries me, lol. should I wait till it actually starts sticking to replace it, cause a few mods are going in before i put a clutch in, so i hope it last's.
