Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 ZO6 Weak links??
Old Oct 28, 2006 | 06:39 PM
02WSsicks's Avatar
Default C5 ZO6 Weak links??
What are the weak links on a c5 Z?? Output shafts? what else?
Old Oct 28, 2006 | 07:05 PM
T-maxx's Avatar
In stock trim you shouldn't break anything on the C5 Z. What are your plans for the car? Drag, track days, or just a daily driver? Here are a couple of minor things that may go wrong. Fuel gauge won't work, seat rocking while driving, colum lock on the steering wheel, ect..
Old Oct 28, 2006 | 07:21 PM
michael402z06's Avatar
get a dte strut brace, left output shaft and clutch and you shouldn't have to worry about anything other then the engine.
Old Oct 28, 2006 | 08:08 PM
silver98formula's Avatar
Drivetrain depending on what you do with it. That has been the weak part on my FRC. Everything else is holding up like a champ.
Chris
Old Oct 28, 2006 | 11:30 PM
96-speed's Avatar
The Driver is the weakest link in a stock C5 Z06.
Here's great advice: If you ever feel wheel hop, lay OUT of the throttle.
Ryan
Old Oct 29, 2006 | 06:28 AM
02WSsicks's Avatar
Looking to go Supercharged or Turbo in the future.
Old Oct 29, 2006 | 02:53 PM
T-maxx's Avatar
That's a whole new game. Hang around the F/I section. A DTE brace and output shaft will be the least or your problems. There are some sick turbo kits on the market right now
Old Oct 29, 2006 | 08:37 PM
Drewstein's Avatar
The Z06 C/R is high, so it doesn't agree with boost all that well. I say 8# will be your max but that still nets 575-600rwhp since your heads are decent.
Other than that it's the rear end that needs to be tended to. I'm still on the stock rear but I'm aware I'm pushing my luck.
Old Oct 29, 2006 | 09:42 PM
~JOSHUA's Avatar
If you pop for a Kenne Bell twin screw, you're gonna bust every single bolt on that car. You'll fry the clutch, destroy the syncros, bust the half shafts, collapse your ringlands and suck every last Franklin out of your bank account.
What else have you got on your mind aside from forced induction?
Old Nov 10, 2006 | 09:30 PM
Genesis_26317's Avatar
That sounds like so much fun to do!!!
Old Nov 11, 2006 | 02:46 AM
Sigforty's Avatar
01's have weak rings in the engine, there is also weak blocker rings in the trans, and the trans shift fork.
Old Nov 11, 2006 | 05:34 AM
cantdrv65's Avatar
Post
The number one weak link on any M6 C5 is the dreaded column lock...Get the latest recall done, it eliminates it altogether...
Old Nov 11, 2006 | 07:28 PM
NEED2SPEEDLS1's Avatar
i heard the Z06's dont have that bad of a time with column lock. Mine seems to be working great... knock on wood. I want to do all the things that people listed above to make it real strong. dte brace, ect ect.. anymore info guys?
Old Nov 11, 2006 | 08:06 PM
V-seriesTech's Avatar
Nope, that pretty much sums it up.
Diff, trans...thats all I have seen, as far as failures.
Old Nov 12, 2006 | 10:39 PM
Steve01SS's Avatar
yeah. Clutch, Output shaft... and should get a DTE brace also.
