Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Help!!!
Old Dec 14, 2006 | 06:44 PM
02402RAMAIR's Avatar
Default Help!!!
Ok guys, my corvette seems to have a electrical problem..every time the rear wheels start to roll, the car just kills itself. Does anyone have a clue as to what sensor or what could be causing this?
Old Dec 14, 2006 | 06:50 PM
T-maxx's Avatar
What do you mean by " kills itself " ?? It might just be the T/C.
Old Dec 14, 2006 | 06:51 PM
silverstreak_ws6's Avatar
ok guys..the "column lock" code is what is going on. Does anyone know how to fix this?
Old Dec 14, 2006 | 06:52 PM
we put it on the lift..as soon as the tires turn, it dies, even in neutral, we turned the tires, it died
Old Dec 14, 2006 | 07:04 PM
DoesSpeedTurnUon's Avatar
yea you need to get a column lock bypass, you can try pulling the #25 fuse also to reset everything, it senses that the column is locked and you can still drive it, which throws a flag to the computer and as a safety precaution wont let you go over 2mph.
http://www.thunderracing.com/catalog...d=220&pcid=156 order this.
http://forums.corvetteforum.com/show....php?t=1015483 read that for more info
Old Dec 14, 2006 | 07:11 PM
is the #25 fuse the bypass, or where can u get a bypass
Old Dec 14, 2006 | 07:21 PM
turn the ignition on... pull it out for like 5 minutes and then turn the ignition off, and put it back in. Its under the passenger floor mat up by the firewall.
Old Dec 14, 2006 | 07:52 PM
ok..that didnt work, how do we get a column bypass
Old Dec 14, 2006 | 07:55 PM
order it from thunderracing click on the first link i provided. is the steeringwheel actually locked? if it is, you'll probably want to take it to GM, its a recall, they may fix it for free
