Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
corvette dyno numbers
Old Jan 17, 2007 | 04:57 PM
01gtmustang's Avatar
Default corvette dyno numbers
would a stock 2002 regular corvette dyno the same as Say a stock 2002 z28.???
Old Jan 17, 2007 | 07:04 PM
AllShowNoGo's Avatar
Yes it would. There is an article that shows this but i cant find it right now.
Old Jan 17, 2007 | 07:11 PM
'Trust''s Avatar
Yup, in the article in question the LS1 F-bod actually put more down than the LS1 Vette'
Old Jan 17, 2007 | 07:15 PM
mdhmi's Avatar
It's not uncommon for an F-body to dyno higher. Driveline differences, etc.
Old Jan 17, 2007 | 07:55 PM
Azrael's Avatar
I think it was the IRS vs. Live axle...
Old Jan 17, 2007 | 07:57 PM
LS1C5Vette's Avatar
I would like to see the sheet, I would think the z28 would be a few Hp less
Old Jan 17, 2007 | 08:04 PM
Azrael's Avatar
Here is the '98 MY comparo:
Old Jan 17, 2007 | 08:09 PM
^^^Thank you, thats the article i was looking for.
Old Jan 17, 2007 | 08:20 PM
Azrael's Avatar
No problemo!
Corvettes are usually faster than the F-Body cars because they are much lighter... Of course then there are the Vettes with the LS2, LS6, or LS7...
Old Jan 18, 2007 | 10:25 AM
ok thank you. Yeah i knew the vette was faster because they weigh less. Did the vettes have anything different in the engine than an f-body.?? or were they pretty much the exact same thing.
Old Jan 18, 2007 | 10:45 AM
Sneakyws6's Avatar
On the tree
On a dyno of a vette versus camaro both with LS1's and auto's the camaro will dyno higher due the vettes tranny being in the rear of the car. Every sheet I saw of a stock versus stock put the vette about 10hp down the F-body.
The actual motor is exactly the same, vette uses different air intake system (not actual intake, both use the LS6 intake) and has different exhaust manifolds. The vette also has a more direct exhaust system that is less restrictive than the F-bodies.
Old Jan 18, 2007 | 11:03 AM
MagiC5's Avatar
I dont' see how having the trasmission in the rear would yeild a lower hp out put...
however the reasoning has already been posted... The LS1 in the vette is the same LS1 in the F-body except oil pan... The vette is equipped with a power robbing IRS where as the F-body gets the live axle.... aka drivetrain loss...
id also guess with the larger rear wheels found on the vette compared to the f-body also adds a few extra pounds in the DT that need to be turned.
I've seen where an extra 11lbs in wheel/tire combo = 11rwhp loss on a dyno jet on an 00 camaro.
The above example is not to be confused that 1lb in wheel weight = 1rwhp loss. just what happened.
Old Jan 20, 2007 | 09:27 AM
Sneakyws6's Avatar
On the tree
Magic that was my point, the vettes drivetrain causes alot more driveline loss than the F-body. I remember seeing a article back in the day about how the extra parts that GM used to hook the torque tube to the motor and the tranny being on the rear end being the main reason for the high drivetrain losses.
Old Jan 21, 2007 | 01:11 AM
dixonk's Avatar
Actually my bone stock 02 T/A dyno numbers were 292 rwhp with 276 rwtq and my bone stock 02 C5 Coupe dyno numbers were 302 rwhp with 323 rwtq both were done on a dynojet using SAE correction. It is kind of strange that the vette put out more rwtq than rwhp. But I did see more hp in the vette and there is also no comparison in running it on the streets. The vette hooks so much better than the T/A.
Old Jan 26, 2007 | 12:07 PM
greysteel_M6's Avatar
Both use ls6 intakes on 01'+ lower years use the ls1 intake. I think the specs on the cam are marginally different- correct me if I'm wrong. The f-body weighs a couple hundred lbs more and the vette has superior airos. The vette should put down a little less considering the I.R.S.
