Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C4 question....what do these lights do?
Old Mar 5, 2007 | 11:30 AM
WS6NIGHTMARE's Avatar
Default C4 question....what do these lights do?
I know its not a C5, but Im not a member of any Vette forums so maybe you guys can help me.
My boss has a 94 Vette and we noticed last week that it has lights up front on the side of the bumper that werent working, so we put in new bulbs, and they still didnt work. But after closer examination we realized that we didnt even know what these lights were for. Not the blinkers, hazards, backup, or anything
The ones in front of the orange spot. They are a white bulb also.
Old Mar 5, 2007 | 12:23 PM
Todd157k's Avatar
did you try the parking lights? on C5s, there are DRLs that are only on with parking lights.
Old Mar 5, 2007 | 12:33 PM
Yep, Ive tried every combination of on and off I can think of and I get nothing. I checked the fuses inside the car, and found one right by the light in question, but it was also good.
Old Mar 5, 2007 | 11:42 PM
NoChrome's Avatar
I know on some higher end cars the light in that general area is to light up the area around that corner of the car when the blinker is turned on, but if it dosent turn on with the blinker Im at a loss. By the way what color were the bulbs that you pulled out. There dosent seem to be a blinker on that side for the front, so maybe if its an amber bulb its supposed to be a blinker but its broke.
Old Mar 6, 2007 | 12:03 AM
Well thats what it seems to be, is an illumination light that comes on with the blinker. Its just not working. Another member on another board says thats what his C4 does, so I guess we just have to find the fuse/relay for them.
The amber spot there is the blinker. The bulbs that go in the clear area, the area in question, are white.
Even though these dont work they dont cause any problems of any kind, so heh.
Old Mar 7, 2007 | 10:27 AM
kosovobandit's Avatar
It is the turn light it lights the turn you are going into
Old Mar 7, 2007 | 11:11 AM
20ls100's Avatar
did you try putting the car in drive to check them? with the key on or the car running? my 81 had them and i seem to remember they would only work with the car in gear? not positive though?
mitch
Old Mar 7, 2007 | 12:07 PM
~JOSHUA's Avatar
Default Here is the answer...
The cornering lamps, located on the side of the front fascia, provide more light in the direction of a turn. When the headlamps or parking lamps are "ON," moving the turn signal lever will turn the appropriate cornering lamp "ON" as well as activate the turn signals.
Old Mar 7, 2007 | 05:53 PM
Thanks for all your help guys. I diont suppose anyone knows where the fuse/relay is for them?
