Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Installed Z06 shocks on my C6 (pics)
Old Mar 8, 2007 | 03:19 PM
Larry's Avatar
Default Installed Z06 shocks on my C6 (pics)
What a job this was! Thanks heavens for my $1.49 Sears tool (that I made). You have to compress the shocks to install and remove. Without being compressed they won't come out. With them compressed you still have to work them out.
I attached a pic of my factory shocks verses the Z06. Much larger diameter and much stiffer.
My hope is they will help eliminate wheel hop.
Old Mar 10, 2007 | 12:40 PM
chuck01's Avatar
next time try zip ties and an extra jack.
Old Mar 10, 2007 | 01:06 PM
Larry's Avatar
I didn't think about zip ties. But this wire worked pretty well. I suppose $1.49 was being a little extravagant too. LOL!
Old Mar 10, 2007 | 01:21 PM
MICAH HERRON's Avatar
From: Johnsonville, SC; but orginally from GAINESVILLE, FL
So, what do you think? Any noticeable differences?
Old Mar 10, 2007 | 02:39 PM
Larry's Avatar
Haven't had it to the track yet to test for wheel hop. Not sure the street is the best test. Ride quality is good. Maybe slightly stiff ride but very acceptable.
Old Mar 14, 2007 | 08:23 AM
Larry's Avatar
Originally Posted by Genesis_26317
What other suspension mods have you done? Any sway-bars, etc?
I have the Z51 rear bar mounted in polyurethane bushings. The poly bushings hold the bar better than the factory rubber which gives it somewhat more stiffness by not allowing it to move or squirm as much in the bushings.
Old Mar 14, 2007 | 04:32 PM
Larry's Avatar
Are you going to do any more mods in the near future, I would like to follow the suspension work overall.
Love to hear track times too.
I don't have anymore suspension plans at the present time. I do plan to go to the track this Friday. Might have more suspension plans after I see how it launches.
Old Mar 14, 2007 | 04:55 PM
M3Corvette's Avatar
Larry, you should find it better. I get alot of wheel hop on my C6's (even the Z51), but very little on the C6 Z. I guess you will find out soon.
Old Mar 14, 2007 | 05:03 PM
Larry's Avatar
I can't imagine needing any shocks stiffer than these Z06 shocks. The double adjustable might be better but hopefully these will get the job done. Some say the Bilsteins eliminate wheel hop and they are not adjustable. And I rather doubt any stiffer than these Z06s.
And I bought both from Fred Beans for $105.41 delivered.
Old Mar 15, 2007 | 12:47 AM
chuck01's Avatar
I upgraded my 01 A4 with Z06 sway bars, 04 Z06 polished alum. wheels and F1 Supercar tires. both made the car handle 100 times better. Now I have 04 Z06 shocks, ready to install in my garage and hope it helps more with handling as well has traction/wheel hop. Wanted to get 06 Z06 shocks, but got great deal on new 04 Shocks.
Thanks for the write up...
